Results 1 to 9 of 9
    Aug 19 2008
    Boston
    Upgrading to Carplay - SQ5 with B&O
    Looking to upgrade my 2014 SQ5 to a carplay 10" screen, either the RSNav or one of the other Aliexpress units. I keep seeing that some of them aren't compatible with all the versions of the factory radio. Can someone tell me if I am able to upgrade with my B&O system?
    Feb 12 2008
    Michigan
    you have nav too? yes you can upgrade! if you look on the rsnav website there's a list of the different MMI systems and you can pick out which one you have. guessing you have 3G MMI high plus, same as me it is compatible
    Veteran Member Four Rings ILVTRANCE's Avatar
    Dec 19 2012
    New York
    yes you can upgrade. I also have a 2014 Sq5 but without B&O running RSnav S3
    2014 SQ5 P+ | 034 Stage 2 ECU + TCU | 034 190mm crank pully | 034 Street Density motor mounts | 034Motorsport S34 Carbon Fiber Intake | Merc Racing HX V3 | Bilstein B8's w/ H&R Springs | 034 Trans insert | RSNAV 10.25
    NEW EDM MIX APRIL 2021 https://soundcloud.com/matt-scheinwa...in-my-basement
    Mar 07 2020
    Minnesota
    This might be helpful - I have no other information about it, came across it looking for something for another vehicle:
    https://www.navtool.com/audi-q5-2009...e-carplay.aspx
    Aug 19 2008
    Boston
    Quote Originally Posted by Fast4esT View Post
    uh I dont actually know if I have Nav, LOL I'll take a look when I go back to my car
    Jul 16 2018
    Atlanta
    A US B8.5 vehicle is going to have either Concert (dash unit says Audi concert; no navigation, not MMI; sometimes referred to as CAN bus infotainment system) or MMI 3G+ (dash unit says Audi multimedia; marketing term MMI navigation plus; MOST bus). The front end infotainment system is what you care about when looking at these modernization options. The back end sound system is not relevant (US B8 vehicle going to have either standard sound system or B&O sound system).
    Aug 19 2008
    Boston
    Quote Originally Posted by Smac770 View Post
    My dash says Audi Multimedia. So I will shop for an mmi 3g unit
    Jun 25 2019
    Ottawa/Ontario/Canada
    Just bought an inav for my 2015 sq5 today. 4x4shop.ca. All these units run audio through the mmi jack. Hoping to install tomorrow. Will update post.
    Junior Member Two Rings schism75's Avatar
    Aug 13 2022
    16' SQ5 & 19' KTM SUPERDUKE 1290 R
    WMASS
    I picked up the Apple CarPlay unit from ECStuning and it works well. Install is relatively straight forward for my 16' Sq5 with the Audi Multimedia. The trickiest part was finding the connection to the CANBUS that was tucked away behind the glove box on the left hand side. I believe the connector was colored orange ,but don't quote me on that. I also ran there mic all the way to the stock mic location near the map lights and wedged it in front of the stock mic and cover which now can't be seen.
    16' SQ5 Quattro Premium Plus Moonlight Blue
