    Sep 17 2005
    Fremont, California
    Dynamic+ RCO Control Arms Now Available from 034Motorsport!
    The 034Motorsport Dynamic+ RCO Control Arms for MQB and MQB Evo Audis and Volkswagens are engineered to significantly improve the handling performance of Mk7/8 Volkswagen Golf/GTI/Golf R and 8V/8V.5/8Y Audi A3/S3/RS3 models. Designed as a true drop-in upgrade for the factory stamped steel control arms, the Dynamic+ RCO Control Arms provide an additional 0.5 degrees of caster and allow for approximately 1.2 degrees of increased negative camber adjustment, while also dropping 1.5lbs per corner due to their forged aluminum construction. Dynamic+ RCO Control Arms utilize 034Motorsport Density Line Bushings to reduce deflection and improve handling precision beyond factory levels.
    Dynamic+ RCO Control Arms also add 0.5 degree of additional caster to each of the front wheels to improve high-speed stability and cornering ability. This addition of positive caster increases dynamic negative camber while cornering, maximizing the available grip when turning.
    Dynamic+ RCO Control Arms are the ideal solution for enthusiasts in search of enhanced handling performance, confidence-inspiring grip, precise steering response, and maximum stability throughout turns. Equally well-suited for the street and track, Dynamic+ RCO Control Arms deliver a perfect balance of performance, durability, and comfort. Dynamic+ RCO Control Arms were tested extensively on the street and at the track with multiple MQB & MQB-Evo Development Vehicles before release to ensure that they deliver excellent performance and durability.
    Check Out Our Guide to Handling Combinations and how Camber, Caster, and Roll Center Affect Your Handling Performance!
    Features:
    • Adjustable Camber range from Stock to an additional -0.5°
    • Additional Caster of ~0.5°
    • Forged Aluminum for Strength and Lightweight
    • Stock 6lbs 4oz
    • 034 RCO Arms: 4lbs 12oz
    • Utilizes Density Bushings to Help Reduce Deflection, Maintaining Proper Alignment Under Load
    • Direct Replacement of OE Arms
    • Compatible with:
    • 034Motorsport Dynamic+ Camster Mount Pair, Volkswagen & Audi MQB and MQB Evo (034-601-1023)
    • 034Motorsport Dynamic+ RCO - Camber & Roll Center Adjusting Ball Joints, Volkswagen & Audi MQB and MQB Evo (034-401-4013)
    What's Included:
    • Left Control Arm
    • Right Control Arm
    OE PART INTERCHANGE:
    Left:
    • 81A 407 151 C
    • 5Q0 407 151 J
    • 5Q0 407 151 R
    Right:
    • 81A 407 152 C
    • 5Q0 407 152 J
    • 5Q0 407 152 R
    NOTE: NOT COMPATIBLE WITH 8S TTRS UNLESS YOU CHANGE BALL JOINTS
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Ha. About time. I got all your other stuff but ended up getting whiteline arms since you didn't offer them. Would be nice if you offered with more caster. I weighed them on good scale, and those (also aluminum) were basically the same weight as the steel ones.
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Veteran Member Four Rings Gberg888's Avatar
    Jun 16 2011
    996tt
    MA
    Will these fit the RS3 air ducts with their zip ties?
    Garage:
    04 996TT X50, 06 Boxster S, 88 911 Targa, 16 S3
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Quote Originally Posted by Gberg888 View Post
    yeah, though not as exactly as with the steel ones - The whiteline arms are very similar though you can get those with more caster.
    Also, the ad copy conflicts. It says both: "allow for approximately 1.2 degrees of increased negative camber adjustment" AND "Adjustable Camber range from Stock to an additional -0.5°". Those are very different statements with the first much more desirable than the second. I did the arms with more caster and camber plus the 034 balljoints - it drives very different now; much "edgier" with a total of -3 degrees camber.
    Veteran Member Three Rings Chaoscreature's Avatar
    May 26 2018
    2018 A3 Quattro, 1995 Porsche 993 C2, 2006 Jetta TDI Special Edition, 1956 Willy CJ5
    Vista, CA
    Nice work 034!
    Those look great
    "If everything is under control, you're going too slow" - Mario Andretti
