Results 1 to 4 of 4
    Senior Member Three Rings GodFatherMav03's Avatar
    Oct 15 2009
    2012 Audi A6 3.0T Prestige, 2013 Audi Q5 S-line 3.0T
    Gaithersburg/MD
    01403 Glass-break sensor rear Audi A7
    Hey guys I had this come up 01403 Glass-break sensor rear - sporadic -open circuit
    I recently bought the car like month ago. The car was originally tinted but the tint was remove to pass MD state inspection by the dealer. When they removed the tint they did no do a careful job apparently in removing the tint on the rear window. Some of my defrost strips are not working from it. I don't know if that has anything to do the the glass break sensor or its something else. But its getting quite annoying having my alarm go off a couple times at night. I have not checked out the connection for the circuit yet but I will look at it when i got some time. Any idea where it would be? I hope I don't have to completely replace the rear window. Any thoughts on this would help.
    Veteran Member Three Rings Vinng86's Avatar
    Jul 20 2018
    Toronto, ON
    Most likely the sensor has become detached from the glass. Especially since you mentioned some defrost strips are also not working. It seems like a common issue when people remove tints improperly.
    I'd check the edges of the glass near the trim and look for any loose contacts.
    2014 Audi A6 3.0T Technik(Prestige) S-line w/ Black Optics
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    https://www.vwaudiforum.co.uk/forum/...ensor-location
    Take a read through this to see if any of it might help.
    Oct 15 2009
    Gaithersburg/MD
    Awesome thanks for the info
