Description
The Catless downpipe (102mm turbo outlet) For Audi TTRS IS/RS3 8V is the ultimate choice power adder for your exhaust system. Offering an aggressive and unique sound from your engine with complete unrestricted air flow for unmatched maximum power. Enjoy proven performance gains and leading features such as bolt- on direct fit install, long-life construction, cast sections, and amazing sound. the downpipe crackles and bangs but is quiet to the relief of the turbocharger. There is also a substantial weight saving in comparison to the factory catalytic converter. The decat is mandrel-bent for better gas flow and maximum internal size to ensure ultimate performance without the loss of mid-range torque.
Will fit the following models perfectly
Audi TTRS IS/RS3 8V,
Audi TTRS 8S 2017+
Audi RS3 8V 2017+
Features
Thermo wrapped
102mm turbo putlet pipe, then 89 mm until the mid-pipe
exhaust fits stock Turbo
dual 76mm mid-pipe
100% perfect fit, plug and play
made out of high-quality stainless-steel cast
CAD-designed and flow optimized
2 lambda probe connections
Less thermal load on the turbocharger
More power by reducing back pressure
Significantly higher torque
Enhanced Exhaust Note & Turbocharger Sounds
