Hi gang- hoping someone can point me in the right direction. I’m stumped. Short version is the subject line of this message. Bi-xenon AFS, by the way.
Maybe 2 years ago had the flickering and dipped message (right side) occasionally. Usually returned to normal operation w/o issues for some time, so just kind of bounced along while trying to figure it out (learned lots reading Audizine.) Then- as luck would have it- it crapped out (low beam totally out) during an inspection. Because of tight schedule/timing, etc. I sprang for a new headlight assembly and replaced it. No more issues for the past several months. Whew.
Then- tonight- the fuggin’ right dipped headlight message. Big time ugh as that new light was 800 bucks. :( It’s a Magnetti Marelli and it seems unlikely I’ve a bad one (as it’s been working flawlessly.) I drove for a bit, pulled over, got out and verified the low bulb not lit, shut off car, re-started and all fine. Gotta love a good electrical mystery.
Any opinions on next moves? Again I don’t think it’s the new assembly, seeing as this seems to be the exact thing that was happening before replacing it (in that it’s fine, then not, then fine. Makes me think I replaced a good assembly.)
Really appreciate any advice you may have. I’m trying to figure this out and give the shop guidance (not averse to wrenching and Lord knows I’ve done plenty in the past, but because of physical issues, the cold and no garage depending on the local indie.) Thanks!
