Hello, All,
I've been reading along for awhile, but this is my first post (fairly new member) about the car (2011 S4 MT, no mods) I've tried to search, but haven't found anything on point yet. I don't really know much of anything about fixing cars, so if (when) my ignorance shows through (or too much info), please forgive me!
I've had the car since 2018 and had no real issues until ~ May 2022, when a warning/message appeared on car info system - "coolant expansion tank low" (or words to that effect). Car did't overheat. Got under hood quickly and found expansion tank empty. When I removed the cap, I heard a little whoosh of air (like there was suction within system?) I filled expansion tank and went on my way.
At oil change/inspection Aug. 2022, very small coolant leak noted - dried coolant at bottom of engine compartment. Shortly after this, yellow "oil low" light comes on, seemed weird, since I just had the oil change, but regardless, I put in ~ 450 mL oil, and went on my way. For what it's worth, before all of this, car didn't seem to consume much oil - I'd get the yellow oil light on after ~ 4000-5000 miles after oil changes, and would then need to add about 400-450 mL about every other month until next oil change.
Sept., 2022 - "low coolant" message comes on again, and expansion tank again empty. Again quickly filled, no overheating. Car into shop for coolant leak diagnosis - passed "coolant block test", but leaks found at: PCV housing, upper valley transfer pipe, water pump slightly seeping from seal. Fairly significant replacements/repair done at this point - new water pump, T-stat, PCV assembly, coolant pipes, crankcase ventilation cover gasket ( invoice also mentions oil separator under crankcase gasket heading - not sure if that's the same thing?), along with alternator drive belt & supercharger belt, and oil / filter changed.
Oct. 2022 - after picking up car, drove about 30 miles when bad misfire developed, EPC and "check engine" lights on, and coolant level down to 1 inch below "min" line on expansion tank. Car back to shop - pressure tested coolant system, and held pressure - suspected air pockets may have been in system, eventually filled, accounting for drop coolant level. Bad ignition coil / spark plug found, and replaced, curing misfire, dash lights out. Oil not discussed.
Oct., 2022 - drove car for about 200 miles when yellow "low oil" came on, and a few minutes later red "low oil - add oil immediately" light came on. When I lifted the hood, that apparently reset the oil warning lights - they went out. Called the repair shop - actual low oil problem doubted (just had oil change) - suspected sensor wires loose, corroded, etc. I was wary of over-filling oil, and per discussion w/ repair shop, was to just keep lifting hood to reset lights, until I could get car in for inspection. MMI oil level gave messages about "warm car, engine off - read in two minutes", but I couldn't get a reading from it.
Dec, 2022 - car sat for a month, not driven, while recovering from surgery. Once I began driving it again, oil lights would come on every couple of days - I'd lift hood, which turned off lights, and I'd go on my way. No oil added.
Jan., 2023 - got a dipstick (ECS #06E 115611H) and placed it the other night - it came out bone dry. My first thought was dipstick too short, but further research suggests it's the right one. So I had the car in for an oil change (different shop), just to find out how much oil was really in the car - 3.4 quarts! I asked my brother-in-law (retired mechanic) where all the oil went - he asked if I'd looked at the coolant lately. I had not - the level was staying about the same, and temp steady/normal. So I looked at the coolant in the expansion tank and it looks like a milkshake - thick, creamy, orange/pink. I called the repair shop with this info, and there was discussion about whether any of the coolant system repair work might somehow be connected to the current situation - unclear. I had thought I had read about coolant in oil being an indication of possible PCV failure, but maybe that was not about 3 liter engines. Other possible explanations were also discussed - bad cylinder head (?). I haven't noticed any oily substance out of the exhaust pipes, or abnormal smoke from exhaust.
I would be eternally grateful for any thoughts, suggestions, diagnostic ideas on the possible/likely causes of the situation (what to check/test first, second, etc) and any thoughts on where those three quarts of oil went.
Thanks so much in advance for any help you can give,
JSL4
