I've been having an increasingly more common issue related to my transmission. I get a Transmission Malfunction error. The cluster warning indicates I should stop driving and shift into park or neutral. I then promptly pull over, but the car will NOT let me shift into park or even neutral. On two of the occasions, it shifted into neutral before I stopped driving and I had to use momentum to get into a paring spot. I then have to turn the car off, and I'm sometimes able to shift into park. However, most of the time, the car recognizes it as neutral still, despite the shifter being firmly forward. I usually have to wait a minute or two, cycle the car on and off a couple of times, then I'm able to shift into park. While this happens, the ACC Guard Unavailable error shows up. Again, cycling power off and on usually clears this.
Some additional info:
- This always seems to occur when I'm cruising along at about 70 mph. It's typically about 30 minutes or so into my drive. During this time, RPMs are normal and the car feels absolutely fine.
- It's now happened about 4 or 5 times. Each time, is roughly the same conditions just cruising along barely on the throttle.
- It does not seem dependent on the ambient temperature.
- I have noticed no other issues with my transmission. It shifts fine the rest of the time. On plenty of local trips, I have zero issues.
- My car does have an EPL transmission tune that's been on there for probably 4 years.
- I had my clutch replaced about 4 years ago due to slipping. I have had no slipping issues since then.
- Quite frankly, I've been babying the car the past few months. I hardly drive it and when I do, I'm becoming an old man.
- The strangest part is that this error will occur, I'll go through the process outlined above, then the rest of my drive is trouble free.
Anyone ever experienced anything similar? I searched the forum and most people tend to get the transmission malfunction where they are allowed to continue driving. I wish I had a photo of this error, but I was a bit panicked every time as traffic whizzes 2 feet by me at 70 mph.
I figured possible issues:
- Mechatronic unit - seems to cause a lot of issues like this
- Temperature, but seems unlikely given the low ambient temp and the fact it doesn't happen again for the rest of a 1.5 hour trip.
