Hi, I'm unsure how to go about fixing this.
Both rear windows seem to go down twice before they go all the way up to the closed position.
For example if the windows are down and I press the switch to go up they go down first about halfway down from their position when they were open, then they go up a couple inches only to go all the way down before they slowly start to go all the way up again and close. Both rear windows do this same behavior.
The regulators were changed on both sides because the window on the passenger side would fall down a couple inches occasionally, i did both sides as a precaution, but the windows still act the same.
I have 2 new (used) motors from the junk yard, but I'm just curious before I install them if this has anything to do with pinch protection or if anyone has had this issue and can provide a solution for this.
Thanks
Sent from my SM-G986W using Tapatalk
