Getting ready to replace all 4 tires on my '14 A4, P+, S-line with 245 40R 18 tires. Best I can tell, these may be the original tires from the car. So based on mileage and age, it's time for new tires. So no big deal there.
What I'm confused/concerned about is that I thought based on wear bars, there were a few more miles left. But the other day front drivers side tire had low air pressure. Pumped it back up and a few miles later it was losing air so quickly that you could hear it. Couldn't get in for a repair (figured ran something over), so put the spare on to buy a day. That's where I realized that the inner inch or so of the tire was heavily worn. So much so that the tread was separating from the sidewall, and you could see the belt underneath. Looked at the other front tire, and while not as bad it wasn't by much, wear pattern was really similar. I'd never seen or heard of similar wear. Did a quick search and found a few threads on Audiworld and here in the S5 forum where this has happened. So happens occasionally, but not sure I saw any answers on why.
From the wear, if anything it seems the tire pressure may have been a bit too low, but if so why is only the inside and not outside worn the same way? I have been good about inflating to pressure on the door jamb, and if anything maybe relied on the TPMS too much...only check pressure when I get a warning. The threads I saw with similar wear also mentioned toe. I would think (but am no expert) that if camber was the issue, more than just the inner inch or so would have excessive wear.
When I first got the car, it tramlined really heavily. Tracked ruts and could be really twitchy off-center. First road trip I did in the car was a bit unnerving at speed. Got the car aligned at a local shop (Tru-Line) after that, taking it from what was out to in spec. Car tracked much better.
As I get ready to put on new tires, any thoughts on what may have caused this? This seems like it has the potential to be really dangerous if it wasn't caught, and would like to not have to worry about it as the next set of tires approach end-of-life.
Pictures of the tire wear, tread separation, and before/after alignment specs are attached.
