Results 1 to 7 of 7
    Jan 08 2023
    Queens New York
    S3 battery concern
    I'm concerned about the battery in my 18 S3. Daily use, everything is fine. If I park & turn ign on for 10 min to check my dashcam, I get a low battery warning on my dash. If I don't ck the dashcam, all is well. I was thinking about getting a power pak, but I'm wondering if this is a sign to just spring for a new battery. Opinions please.
    Dec 25 2004
    Earth
    Both my OE S3 batteries lasted 3 years each...so if yours in a 2018 and its freezing where you live...ya might want to seriously consider replacing the battery
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Jan 08 2023
    Queens New York
    Will I need to program a new battery? Is glass matt the way to go, or just get a regular battery from Costco?
    Veteran Member Three Rings XMetal's Avatar
    Nov 02 2017
    CA
    Yes, you'll need to program in the new battery. If you're using the START/STOP function, you'll need something that's made for it, like an AGM or an EFB. Whatever you pick, make sure it has an "Ah" rating as you'll need it to program in the new battery. I just went through this last month - see this thread for more info => https://www.audizine.com/forum/showt...ttery-question
    2018 Audi S3 Premium Plus
    Navarra Blue Metallic/Magma Red - Technology, Dynamic, S Sport, Black Optic, Resonator Delete, Unitronic Turbo Inlet, EQT Stage1 ECU/TCU
    Jan 08 2023
    Queens New York
    I want to report a robbery: Went to local shop, they called supplier. They said dealer only because a new battery has to be programmed. Called dealer. Batt-$295.00, programming-$322.00 = $617.00 Yikes. Audi much closer than VW.
    Veteran Member Three Rings kevin#34's Avatar
    Aug 11 2019
    Rome, Italy
    617 bucks for a new battery, installation and coding is a real theft
    probably no more than half the cost from an indie, and 1/3 buying an aftermarket AGM battery from Amazon or so and installing/coding by yourself
    2020 TT- RS
    ex 2018 TTS
    Nov 27 2020
    Florida
    Quote Originally Posted by jermar View Post
    The dealer doesn't always even 'program' it. I know because I replaced a formerly dealer replaced battery with an identical battery but I did it myself. The old battery was 'coded' incorrectly.
    BTW, at $322 for programming, you can buy a vcds for $200 and be able to code a battery to 3 different cars (+ do a lot more). The coding is literally selecting letters or numbers from 2 drop down menus (battery type and amps) and then inputting the battery serial number. The shop can do the battery replacement and then you can drive car home and 'program' it. Nothing bad will happen. The dealer replaced battery that was coded incorrectly lasted almost 4 years for me.
