Results 1 to 16 of 16
    Veteran Member Four Rings JWebb_C7_Comp's Avatar
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    VCDS to diagnose Brake Pad/Sensor
    Hey guys,
    I got the dressed brake pad warning today. Pads and rotors are less than one year/10k miles. I’d bet a sensor wire is lose or damage.
    Will a VCDS scan tell me which corner to investigate? It’s cold where I live now and my garage floor is a salty mess. I’d prefer to keep my prissy hands warm if possible….
    Thoughts appreciated.
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    The sensor is only on one wheel so my guess is no. But a close look might help.
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    Thanks TexasDFW.
    I pulled a full VCDS on the car this evening. It shows (6) Brake Malfunctions. (5) related to low tire pressure as I had recently swapped summer to winter wheels and tires and then temps dropped. Boyles law being what it is, I had to add a couple pounds and re-set everything. All good there now, but VCDS doesn't forget until you tell it to.
    As to the brake sensor, VCDS does not show which wheel sensor is impacted. So, I went "old school", grabbed a small o-ight and checked manually. My specific Audi (2018 A6) should have two sensors (driver's front an passenger's rear). I think our Q has all four corners, but I don't recall at the moment and, the Hondas are a different animal.
    All that said, (1) my rotors and pads look great; (2) it looks like my right rear sensor is simply gone. I don't know if it was cut, or pulled out of the socket (perhaps by ice or road debris - shit happens). I'll yank the wheel over the next few days and see what's what. I might have an extra sensor in the spare parts box, as I recall accidentally ordering pads (which typically include sensors) and - separately - sensors for one of the cars over the past year or so, and I'm not one to toss potentially useful, current equipment like a sensor wire that can be used on two of the cars in our "fleet". Assuming I have the right sensor, I'll connect it and zip tie it to the support, keeping if free from likely damage and check my brakes manually (during winter to summer wheel swap and summer to winter wheel swap as I've done for years). I don't like sensors on my cars specifically, but for others in my household, they serve as a good indicator given I don't interrogate them as often as they one I daily.
    If I need a new sensor, I'd be out $10 and 45 min labor ( empty garage, grab jack, stands and wheel support, raise car, remove wheel, remove old sensor connection, add new wire, reconnect, replace wheel, drop car, torque bolts, test drive, replace tools, sweep garage, etc.....).
    TOTALLY MINIMAL EFFORT!
    Sep 16 2020
    West Michigan
    I had a similar issue. Pads are good. Swapped in new sensors, no luck. I believe it is a broken wire somewhere on the chassis.
    It is cold here in Michigan and I haven't had time to really dig into it. So I turned the brake pad warning system off using VCDS.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Cant speak for your S6 but on my A7 there is only 1 sensor on the front left and 1 sensor on the back left. No sensors on the right side.
    I think I have 3 spare sensor wires at this point but no plans to be up near Chiraq for a while. Might be in Franklin Park on Thursday or Friday.
    Feb 15 2011
    Northern VA
    Brake pad sensors were the first thing I disabled when I got my S6.. takes 2 seconds to inspect the pad for thickness, and it's two less sensors that are bound to fail at some point.. not to mention saving time on pad replacement.
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    Quote Originally Posted by Yeoman View Post
    Dot know I could disable the the sensors! I’ll investigate!!
    Feb 15 2011
    Northern VA
    Quote Originally Posted by JWebb_C7_Comp View Post
    You can solder the wires together to get rid of the warning or disable it using VCDS.
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    Yuuuuuuup
    18 S6
    Sep 16 2020
    West Michigan
    I said that in post #4.... nobody reads my shit, I swear! lol
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    Quote Originally Posted by sepheroth86 View Post
    THANK YOU!
    This would have been the BEST solution indeed!
    However, I was sick of the damned light, didn’t have a solder gun here at home, so I connected an extra sensor wire that was sitting in a parts box. I secured it with TWO zip ties, and put my wheel back on the car. By the way, the 2018 A6 sensors are both on driver side: I had confused with my last BMW.
    All the said, when I put summer tires back on, I’m going to (1) solder and (2) use heat shrink wrap to make a permanent fix. I used to simply rely on zip ties on two of my BMWs (both tracked) and never had an issue, but I’ll get fancy with the Audi!
    You guys are awesome!!!
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    THANK YOU!
    PS. Still looking for sensor deactivation in VCDS. If I find it, I’ll post steps!!
    Sep 16 2020
    West Michigan
    https://forums.ross-tech.com/index.php?threads/22141/
    This is what I believe that I followed. Worked great.
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    I'll try it this weekend or next! I think sensors are really good for some folks, but I happen to get a good look at my brakes a few times a year and they're more a nuance than valuable for me, in my case with my minimal usage and maintenance practices......
    Aug 14 2019
    Tampa
    It’s simple VCDS trick used for many things, if you want it disabled, you find where it says the item is installed and uncheck the box.
    18 S6
    Senior Member Four Rings THCarpenter's Avatar
    Jun 26 2021
    C7.5 S6 Prestige
    East Coast
    Quote Originally Posted by Audisthesia View Post
    Yuuuuuuup
    THANK YOU!
    https://www.ecstuning.com/b-ecs-part.../002595ecs04a/
    just saying easy drop in option without soldering in something to have it work again later if needed
    2016 S6 Mythos Black / B&O, Cold Weather, Drivers Assistance, Black Optics
    2016 S6 Mythos Black / Sport, Cold Weather, Drivers Assistance, Black Optics, Night Vision
    "How to spend a shitload of money and still be slow, the THCarpenter story." - sepheroth86
