Results 1 to 11 of 11
    Feb 20 2013
    San Jose
    ECS throttle body tech help - adaptation failed
    Hey guys,
    I bought the larger ECS throttle body and just recently installed it. Im at the point to do a throttle body adaptation but I'm getting an error code.
    Throttle body adaptation: malfunction
    https://www.ecstuning.com/b-ecs-part...hoCLfwQAvD_BwE
    I've installed the new throttle body and harness. Looks to be no fitment issues but I do get the error code preventing the adaptation to start.
    I'm using VCSD - engine 01 - basic settings 04 -
    Any guidance would be really appreciated.
    Mar 31 2008
    eS-4
    CAL*SO
    Who are you tuned by?
    (You might have to repin it)
    Feb 20 2013
    San Jose
    Tuned by GIAC. Oh repin huh? I can do that, any idea where to get the pinout, I'll search around too.
    Feb 20 2013
    San Jose
    Also worth noting I am using the supplied harness adapter. I'll check with my tuner
    Mar 31 2008
    eS-4
    CAL*SO
    I don't believe giac offers a tb file...
    Which is a GREAT thing because you can spend another 650$ and switch over to 034 and they'll have all the files you need
    Feb 20 2013
    San Jose
    Thanks, a while back they told me they support, but I've reached out again
    Veteran Member Four Rings f1torrents's Avatar
    Apr 27 2012
    B8.5 6MT S5 Coupe / B9.5 S5 Coupe
    Guelph
    Feb 20 2013
    San Jose
    As pointed out and now confirmed with GIAC, ECS TB not compatible. giac is compatible with the iabed TB. So i'll go that route once I can. Im not interested in changing tuners at this point.
    Thanks all that got back to me
    Mar 31 2008
    eS-4
    CAL*SO
    An iabed tb kit is at least $500 and if it does work, you are still limited on file options. (Especially since I'm sure giac isn't interested in updates).
    Switching to 034 costs $600 and youll have access to any and all the files you'll ever need. And they are all updated files . Which means your ecs tb WILL work.
    Also 034 is local to you...
    _----------------------------------------_
    Apr 27 2012
    Guelph
    $500 for 6HP is also very poor value for money
    Feb 20 2013
    San Jose
    Quote Originally Posted by f1torrents View Post
    +1 and Agreed. I just put back on my Open element intake. Good enough for me at the moment m
