Which conditions trigger the misfire? If under load it could be coil packs, or VVT actuator, or fuel injector, or fuel pump, or low coolant, or carbon build up on the intake side, or bad gasoline, or...
At 83,000 miles since the rebuild, it likely time for a new timing chain and tensioner. Here's how to check the timing chain tensioner through the peep hole in the front of the lower timing chain cover. This video is for a VW which has some extra plumbing (boost pipe) in front of the peep hole that the B8 does not have, but the procedures (if not the angles) are the same. You can skip to 1:22 min mark. to get to the meat of the video:
There is information on this forum and elsewhere about tensioners (old and new style) and plenty of info for taking on the task of replacing the chain yourself, if you're inclined. DIY timing chain replacement is a huge $ saver, but it's not for the faint hearted. If you do not have the factory service manuals, a one day subscription at
https://erwin.audiusa.com is $35 and you can download PDF's of the FSMs, TSBs, and more for your VIN. On the top navigation menu for the page, point your mouse to "My Account" and select "Subscriptions". I don't remember much past that point, but you're a grown up; you'll figure it out.
If the timing chain has stretched near the max capacity for the chain tensioner you are flirting with catastrophic engine failure. If the timing chain stretched enough then the chain may skip a tooth or two. The 2.0L TFSI is an "interference engine", so if the chain skips then the valves (camshafts, actually) are out of time with the crankshaft, and when the pistons are shoved to the top while the valves are still open, BAM! empty bank account. Scary thought, but peruse the forum and you'll see it is not uncommon.
There are software solutions (VCDS et al) that can measure timing chain stretch. There's a rabbit hole for that here:
https://www.audizine.com/forum/showt...hain+cam+phase
The reasons for misfire are many, so if you can help nail down when the cyl 4 misfire is happening you'll get better and probably less scary advice.
