Results 1 to 23 of 23
    Junior Member Two Rings
    Oct 12 2022
    Utah
    40PSI on Audi A4
    Hi all,
    I recently went through all the trouble of repairing my wastegate & now my A4 is running great. It spools quickly and achieves around 18.5psi untuned.
    Today I went Stage 1 with IE & now I see at times, I'm spooling to 40psi!
    To clarify PSI in certain situations:
    When I was stock tune spooling while in like 3rd or 4th at 2k rpm, I spool to about 23.5psi & when I'm doing a pull in high rpms, I only go to about 18.5psi.
    I haven't done a good pull yet with the tune; however, when I'm in low rpms in 3rd or 4th and spool my turbo, I see myself go to like the high 30s-40psi.
    Maybe it's normal to spool higher when you are low rpm applying the throttle? I don't know.
    I don't wanna blow up my engine. I will be reverting to stock tomorrow morning until I can figure this out.
    EDIT: Stock A4 B8.5 turbo, CTS HFC & downpipe, no resonators or muffler, repaired wastegate, K&M intake, pierson upgraded DV, forge bov kit & IE Stage 1 tune. When I say I've never heard my blowoff valve be that high-pitch, I mean it!
    Thanks for any responses!
    Dan :)
    Dec 03 2015
    Marseille France
    I bet you get throttle closure. Those 40PSI are pre throttle body not what you engine actually get.Boost sensor is upstream from Throttle body
    often coming from too high WG cracking pressure setup compare to tune request cracking pressure.
    Oct 12 2022
    Utah
    Quote Originally Posted by Mars2 View Post
    Ahh. So it sounds like I need to loosen the WG and I should be golden. Didn't even think of where the boost tap was. Thank you!
    Veteran Member Three Rings cybernet99's Avatar
    Sep 06 2014
    2010 A4 S-Line, 2013 MB GLK350, 2004 Yamaha R1 @AlterdA4
    Ottawa, Canada
    That's an awful lot of boost pressure, what turbo is this with? Do you have adequate fueling to be able to match that type of boost level? Even though it is just spiking, be careful ... would hate to see you start melting things because the fueling is not matching the boost spikes, and it leans out for those moments ...
    Follow my build on IG - https://www.instagram.com/AlterdA4
    Integrated Engineering (Sport Short Block | Sport Head Assy | Intake Manifold w 4 x 890cc Injectors), BW EFR8474 Turbo, Custom 4.5" FMIC, Custom 3.5" SS Turbo back Exhaust, Tilton Racing Twin Disc clutch/PP & LWFW, 034 Billet Motor Mounts, AP Racing BBK 380(F)/330(R) floating rotors
    Veteran Member Four Rings Perry01's Avatar
    Jan 22 2016
    Touareg V8 FSI 8V A3 - B8.5 Q5 - MKVI GTI
    Hawaii and Utah
    How are you measuring boost pressure?
    CPMA / CTS K04-0064 / IE custom tune / Wagner FMIC / Custom ZF8 TCU tune
    Veteran Member Three Rings apeck240's Avatar
    Apr 01 2021
    Quote Originally Posted by danstyx View Post
    Hi all,
    Dan :)
    Sounds like absolute, so 25 boost plus 15 atmospheric
    Oct 12 2022
    Utah
    Quote Originally Posted by Perry01 View Post
    P3Gauge attached to OBDII
    - - - Updated - - -
    Quote Originally Posted by cybernet99 View Post
    The stock B8.5 turbo. My AFr pre-tune was 14.7 w/ 91. I will check when I'm out again today and see if the AFr is still around the same.
    Oct 12 2022
    Utah
    Quote Originally Posted by apeck240 View Post
    Sounds like absolute, so 25 boat plus 15 atmospheric
    Sorry, but what do you mean by absolute & boat?
    Apr 01 2021
    Sorry, edited, meant boost
    Oct 12 2022
    Utah
    By 15 atmospheric, you mean it's exiting the wastegate?
    Apr 01 2021
    - - - Updated - - -
    Lol yeah you're reading map sensor, aka manifold absolute pressure, which includes 1 atmosphere which is around 15 psi, so anything over that is "boost". Stock sensor can't even read 40 over atmo, trust me lol
    Oct 12 2022
    Utah
    Ok, phew. So I'm only at 25psi? I assume I just need to loosen the wastegate.
    After I repaired it, I made the actuator adjustable. I just reaaallly don't want to take it back out. I have three times now.
    Oct 12 2022
    Utah
    Just noticed this & remember on a short drive this morning, but my boost gauge at no throttle starts at -18.0psi.
    Established Member Two Rings thatauditech34's Avatar
    Aug 31 2018
    Subaru Forester, 1968 Chevy Nova, 2016 Kawasaki Ninja 650, 2001 Yamaha YZF R6
    Ohio
    40PSI on Audi A4
    Negative number on your gauge means your engine is in vacuum. -18inHg
    Oct 12 2022
    Utah
    Quote Originally Posted by thatauditech34 View Post
    Ah so it isn't an adjustment for 1 atmosphere. Thank you. :)
    Veteran Member Four Rings bb-tt's Avatar
    Apr 30 2018
    2017 TTS, 2011 Avant, 82 c3 vette, 2002 TT (sold), 2010 CC (sold), 2013 Jetta, 2018 Q7, 2019 Tiguan
    DFW, TX
    you dont need to take it out. You are not hitting 40 PSI as Apeck said the map reads boost plus atmosphere and even if you are hitting 25 psi as long as you are not getting throttle cut it is fine. You need to do some wot 3rd gear pulls and log and see what it is doing.
    2011 A4 Avant S-line Prestige
    Nothing to see here, keep moving!
    WPT+
    Oct 12 2022
    Utah
    Quote Originally Posted by bb-tt View Post
    Phew. Glad I don't have to do that. I hate draining my coolant.
    What do you mean by wot? I noticed this morning when I'm doing hard pulls it only pushes to low 20s.
    Jan 01 2012
    2004 A4 Avant
    CO
    If your running the P3 gauge do yourself a favor and get the boost sensor for it so you can pull an actual boost reference from the motor and not just from the ECU readings.
    | 2004 A4 Avant | Gloss Dark Grey |
    | 2.7t K04 swap | 034 RSB | Apikol snub | 17z BBK |Vogtland GT1 Coilovers | Moog adj. UCA's | Peeler reps |
    | 2011 A4 Avant | Brilliant Black | 6MT swap | APR S2 | APR Downpipe | Vogtland Coilovers | RSE's | 034 Sway/tranny mount | Q5 brakes |
    Oct 12 2022
    Utah
    Quote Originally Posted by jjvwg View Post
    I was looking into it. Will do that soon! :)
    Feb 15 2016
    Cambridge,Ontario
    wot = wide open throttle.
    Earth's atmosphere is 14.7 psi so that has to be subtracted from your readings as stated..
    start logging when you put it into third at low rpms... it will chug at first but you want to see how it builds when the turbo kicks in.
    post the results. better be on a good road cuz this car flies at 3rd at red line
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Veteran Member Three Rings Jason11213's Avatar
    Feb 20 2020
    NC
    Hi all,
    Dan :)
    There’s a way to calibrate the P3 gauge to adjust for atmospheric pressure if you haven’t already done that. I think you have to hold the two buttons until it takes you to the config menu. Then scroll through until you get to the Calb option. P3 has the steps on their website.
    ‘15 A4 6MT - Ward Performance Tuning - CTS TR 1070-X - Snow Performance Stage 2.5
    Apr 30 2018
    DFW, TX
    Wide Open Throttle form 2k -~7k in third or fourth gear
    WPT+
    Apr 30 2018
    DFW, TX
    Quote Originally Posted by Jason11213 View Post
    what???? instructions are for wuses, we dont need no stinking instructions
    WPT+
