Wife driving on the way home hit traffic, low oil press light came on, she called
I kept driving, ..bad oil press.. sender.. Heater was only warm, noticed, temps never left cold. Hit traffic, engine and oil temps rose a little, oil press light came on. Repeat... Parked.
Assuming, warmer oil lowers pressure and brings up warning.
Have been reading on this site quite a bit. Hearing the cam bearings as last. Compared to the pics online, under the valve cover looks better than others that were potentially ok on this site. (only clues)
Checked all cam bearings.. Visually, good. no scoring.. Plasti gauge coming? What is a Safe spec?
Developed, plan to pull the pan. title says 84k, odo shows 50k. seller said he didn't know why.
Plan to change, water pump, thermostat, temp sensor, timing belt, tensioner, oil pressure sensor, also adding electric oil pressure gauge for inside actual oil pressure.
Will check oil pickup when I get in there.
Pulled hose off intercooler, out comes around 1/2 cup (115ml) of oil or so.
Now I'm wondering is the turbo bypassing oil and lowering pressure? Is there a way to test this for leaks without running the car? Rebuild? Replace?
While I'm going in there, anything else?
Happy New Year and Thanks for Reading!! Double Thanks for answering!!
