    Active Member One Ring tannergroup2's Avatar
    Sep 29 2021
    Boynton Beach
    Air Suspension fault light after lowering link install
    Hi Everyone,
    Has anyone had an Air Suspension fault light come on after installing lowering links? I bought the cts turbo links and installed at the length suggested on the website. Now no matter what drive mode I am in after about 5 mins of driving the warning comes on and I cannot lower or raise the car. This clears when turning the car off and on again but then happens again. I have to add that after the install I drove the car home and I must not of tightened one link down enough and it separated and completely tucked the rear wheels. It was a 10 min drive and was very close to home and fixed it immediately. Hoping that mishap didn’t cause this. TIA
    Junior Member One Ring dj_intrinsic's Avatar
    Jun 15 2021
    No issues here for 1.5 years of owning my allroad on Ghost Links. Your measurements must be off with each link causing the error. Go buy a caliper and make sure you lengthen/shorten each link exactly.
    - 1st Audi Ever -- 21' Premium Plus A6 AllRoad | Glacier White | Executive Package | Side Assist | 3" GhostLink Drop | 21x9 Vossen VFS-1 wrapped in Pilot Sport AS 4 | Maxton Rear Deck Spoiler | Black Mirror Swap
    - Past Garage -- 18' X3 M40i | 16' X1 | 13' 328i (MT) | 13' MB C350 | 08' Lexus IS350 | 06' Lancer Evolution MR | 01' Jeep Grand Cherokee
    Jan 19 2023
    Quote Originally Posted by tannergroup2 View Post
    Hi Everyone,
    It's possible that links were not installed correctly and are not allowing the suspension to move properly. You should double check the installation to make sure the links are properly secured and that the suspension is able to move freely without any restrictions.
    Sep 22 2020
    Connecticut
    Quote Originally Posted by audisquirrelrye View Post
    Most importantly that the hight sensor arm is positioned correctly. It would be easy to have it reversed. Also front and rear links are different sizes.
    I've had ghost links for two years with no issues.
    2023 Defender 110
    2021 RS6 Avant
    2005 Porsche Boxster
    1997 Ducati 900SSCR
    2019 BMW GS310
    2004 Honda Lawnmower
    SMEG 2 Slice Toaster
    Veteran Member Three Rings Maitre Absolut's Avatar
    Aug 06 2009
    RS6, X3 30e
    Montreal/Toronto
    I've had the CTS links since delivery in November and no issues. Maybe a code was thrown when you drove with the link separated and just have to clear it?
    2023 RS6 | GW / ER | CTS res delete | Ghost links | H&R 10/12
    2023 X3 30e
    2019 SQ5
    2018 M3 CS
    2017 Macan GTS
    2014 S4
    2009 A3 3.2q
