In step 11 it says:
Compress suspension to static ride height. Using 2 16mm wrenches, tighten the 034Motorsport Adjustable Rear End Link to the rear control arm. Torque to 40Nm + 180 Degrees. Note: Upper bolts should be tightened with the vehicle at static ride height!
So if my car is up on Jack stands can I not do this last step until the car is lowered to the ground which would mean I can't get underneath it?
