Results 1 to 4 of 4
Thread: Seized engine
    Dec 23 2022
    Brooklyn ny
    Seized engine
    Hey guys I’ve seem to run into a issue and need some assistance my motor seized in my 2011 s4 I’ve already dropped the engine and transmission out but I can’t separate them there’s only a half inch gap between the transmission and engine how could I possibly go about this
    Thank you in advance
    Senior Member Three Rings JRYtheS4's Avatar
    Sep 08 2020
    Quote Originally Posted by James2264 View Post
    https://www.audizine.com/forum/showthread.php?t=920076
    There's full instructions on how to pull motor and/or trans. These are the factory manuals.
    Sent from my SM-G991U1 using Audizine Forum mobile app
    2011 Audi S4 Prestige 6MT|Full ADS w/ sport diff|Meteor Grey Pearl|Black/silver alcantara|Aluminum trim
    Bone stock except intake
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    You need to pull the CV-Joint-flange / driveshaft out of the drivers-side of the bellhousing of the transmission before it can separate from the engine.
    Veteran Member Three Rings S4Gibbs's Avatar
    Jul 26 2016
    VA
    Quote Originally Posted by S4'ed View Post
    Good idea, but unfortunately not true. To avoid damage to the Flange Shaft Seal, the Left Flange Shaft should not be removed while the transmission is mated to the engine, as you should technically insert a guide tool(which can only be inserted with the bell housing inners exposed. Or at least guide with your hand.) to avoid damage to the Seal.
    James, I'm hoping you got them separated by now. If not, you forgot to remove the flywheel bolts via the access window.
