Results 1 to 14 of 14
    Veteran Member Three Rings TheDude420's Avatar
    Mar 07 2018
    S3
    Florida
    Stage 2 S3 folks - What spark plug gap are you running?
    Just curious what gap everyone is running and why? I have an APR stage 2 high torque and DSG tune on 93 octane. I decided to try APR's new Iridium Pro Spark Plugs and should have them installed sometime next week.
    https://www.goapr.com/products/engin...parts/Z1003100
    There's always conflicting info when spark plugs are brought up. I don't know a lot about spark plugs but I've always heard that a bigger gap = more power but with an increased likelihood of misfires.
    ¯\_(ツ)_/¯
    I'll probably just go with APR's recommended 0.024 - 0.026
    Sent from my SM-G981U1 using Audizine Forum mobile app
    2016 S3 P+, Tech Pack, Black Optics, Super Sport Seats, Mag-Ride, Facelift-Style Headlights, APR Stage 2 High Torque & DSG Tune, Carbon fiber Intake, Intercooler, RS3 Coils, RS7 Spark Plugs, Boost Hose System w/Bypass Hose, Catch Can, AWE Downpipe, AWE Switchpath Exhaust, 034 Motorsport Dynamic Lowering Springs, RSB End Links, Neuspeed RSE102, Dogbone Mount Insert, Neuspeed Rear Sway Bar, EMD Carbon Fiber Diffuser, Carbon Fiber Spoiler, Milltek Cerakote Black GT-100 Exhaust Tips
    Junior Member Two Rings Thejacobhood's Avatar
    Nov 28 2019
    Indiana
    I'm stage 2 on full E, I run Denso IKH01-24 at .024
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Your supposition is correct. There's a great book by Dr. Jacobs on ignition that gives you the science and takes all the "best sparkplugs" opinion out - you can judge by yourself. https://www.amazon.com/Doctors-Optim.../dp/B0050O8NBY . Highly recommend read and on various cars used various of his mods, tweaks and computer - his ignition could kill you or raise the dead depending on your initial status lol. I run the Beru RS7 plugs at stock gap which I think is .028, but on literally everything else including my race cars, Stage 3+ A4 at nearly 30lb of boost, and 11 other VAG cars I ran Denso Iridum at .044. Bigger gap = bigger power as long as your ignition is up to firing them. I'd open up the gap on these too, but these side gap plugs are sketchy to gap I think.
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Apr 11 2012
    stock gap, stock plugs, since 2015.
    Veteran Member Three Rings XMetal's Avatar
    Nov 02 2017
    CA
    Quote Originally Posted by will13k7 View Post
    How often do you change your plugs? I'm only stage 1 and running stock plugs - just wondering.
    2018 Audi S3 Premium Plus
    Navarra Blue Metallic/Magma Red - Technology, Dynamic, S Sport, Black Optic, Resonator Delete, Unitronic Turbo Inlet, EQT Stage1 ECU/TCU
    Apr 11 2012
    Quote Originally Posted by XMetal View Post
    Every 55k or 6 years.
    Nov 02 2017
    CA
    Holy Cow! Even in stock form, Audi calls for change every 40k or 6 years, whichever occurs first.
    Apr 11 2012
    oh, I quoted the wrong 2.0T, it's actually "Perform first at 35,000 miles or 6 years, whichever occurs first. Thereafter, every 40,000 miles or 6 years, whichever occurs first"
    Nov 02 2017
    CA
    So, you're basically just following Audi's intervals? Most tuners recommend cutting those intervals in half. I was curious what others have done in this regards.
    I may just end up following an interval somewhere in between Audi and tuners - say every 30k or so?
    Mar 07 2018
    S3
    Florida
    I've always heard the same for tuned cars. Some people use the stock plugs while tuners recommend colder plugs. The APR heat range 9 plugs I ordered arrived today and will be installed sometime next week. I've used NGK RS7 plugs in the past and I've been on stock plugs for about a year and a half. I'm debating whether to get new coils too
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Pull the plugs, put them under a magnifying glass and measure the erosion... no need for second guessing or just randomly replacing. From a business standpoint, you've already spent the labor to take them out, so no value in measuring, just replace. For DYI, no reason not to measure for yourself how much wear they have in your driving patterns.
    Apr 11 2012
    yeah, I doubt my butt dyno would notice any difference on this car, hasn’t on previous cars. It’s why I don’t bother with upgrading the coil packs too.
    Nov 02 2017
    CA
    I'm more worried about misfires, knocks, etc. due to the plugs more than any butt dyno difference. But as long as the engine is operating fine without issues with that change interval and plug, then stick with what works!
    Apr 11 2012
    makes sense, yeah, all good with stage2, and I abuse it almost every time I drive it.
