Results 1 to 4 of 4
    Established Member Two Rings mrg_B8TFSi's Avatar
    Dec 24 2021
    Audi 2013 A4 Quattro B8, 6-sp man, Audi 1998 A6 Quattro C5, Ford F250 XL 5.4L 4x4
    Northeast PA
    Front carrier removal
    Hello
    I have C5 1998 A6 Quattro sedan that I’d like to do the TB, cam seals, WP/t-stat and all rollers/tensioner..etc. I’d really prefer to make this job easy by completely removing the front carrier, so I’m looking for advice or videos on how to remove the following:
    * bumper
    * how to set aside the condenser
    * how to remove the hood latch or cable
    And any other tips to make this easier would be greatly appreciated. This car had a TB done probably 15yrs ago due to crashed valves bc the belt broke, but I had the head rebuilt and the car has been running great for the last 15yrs but I probably only have 40k mi on this car since it’s not my daily driver it’s basically my winter car and I don’t want to have another belt break on this 2.8L 5V motor.. should I preemptively change this belt based on how long it’s been in service? Or can I go another 50k on this belt?
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Alpaca 2002 Allroad 2.7T Auto 3rd Row, Avus Silver Oxblood 2003 S8, Silver Metallic 2004 Allroad V8
    Portland, OR
    YouTube “Audi 2.8 Timing Belt” and you’ll find a number of great video sources. JHM, Ratchets and Wrenches, a couple people on their own, Justin Ballou, Blauparts, etc. It may be a little harder to find a C5 and not a B5 for the carrier removal, but they’re very similar. It’s pretty easy, especially if you familiarize yourself with the task beforehand. ECS has a pretty comprehensive PDF on a timing belt, also. http://bd8ba3c866c8cbc330ab-7b26c6f3...elt_DIY_r2.pdf
    As far as if you should or shouldn’t do the work, that’s a decision only you can make. These V6 cars love to lose timing and eat themselves, but 40,000 miles isn’t much and I’d be lying if I said I felt you needed to do the job. With that said, the integrity of rubber is only good for so long after years of heat cycling and exposure.
    Veteran Member Three Rings Calif_Kid's Avatar
    Oct 14 2006
    2001 A6 6 spd, 2001.5 AWE stage3 Nogaro 6-speed (sold), 2000 Honda Civic racecar (sold)
    Sunnyvale, Calif
    https://www.audiworld.com/tech/eng63c.shtml which has 4 pages shows the bumper removal and shows the radiator support / front carrier being partially removed although you can also remove it completely. The air conditioning condenser remains hooked up but just swung to the side. The article is for a 2.7T, but should be really similar for a 2.8.
    I've done some timing belt changes by just getting the front lock carrier into the service position which as shown at https://www.youtube.com/watch?v=kFmhJeDpLJU but the service position only allows limited room.
    - Jim
    Dec 24 2021
    Northeast PA
    Thanks all the advice.. yeah I’ve seen the 4-5” of room service position provides but that’s still too difficult for me to get into the crank area and do any work.. I’ll check out these links.. thanks very much
