Over the last few days, I've noticed that my coolant level has dropped under the "min" level in my coolant tank on a few occasions. I keep adding and it still drops.
** No visible leaks or strong coolant smell. **
Never had an issue before. The coolant level warning light never came on, I just noticed the level was under "min" last week, so i started to monitor and top it off.
The car is very well maintained. 50k miles. It runs DS1 tune with stock turbos. I also installed a larger heat exchanger 3 months ago.
2 weeks ago we took a 250-mile trip to the mountains (Lake Tahoe) and there were no issues. Once we got there, I drove around town, lots of snow, ice and slush on the road, but nothing really crazy that should impact my cooling system.
Last week i thought i smelled a very faint coolant odor from the front grill area. Opened the hood and saw my coolant under the "Min" mark. Visually, i did not see any leaks or any sources of a strong antifreeze smell from the top. No white stains.
I topped off the level to "max". Went to town (still in the mountains), car drove normally...it was about 20-25-mile trip. Came back home and the coolant was at the "min" mark!!! :( Still no leaks or obvious smell from anywhere.
That got me worried since next week i need to drive back home, and that's a 250 miles drive.
I topped the coolant to Max, and drove back to town to buy some ramps and tools so I can get under the car and remove the covers and inspect for leaks.
This time, after the 20 miles trip to town .... my coolant DID NOT drop one bit. Like I never lost coolant before.
I went under the car, removed the covers and i did not see anything obvious. No leaks, no puddles, no white stains, nothing really obvious from below the engine area. I only noticed one single drop of coolant on the thermostat housing, but i am not sure if it came from it, or it was from a small spill above when I was topping off the coolant tank. The thermostat housing itself was clean and nothing around it had coolant stains or smell. The plastic covers that go under the car were also dry/clean, with no visible coolant stains on them or smell.
** Keep in mind, before I went under the car to inspect, I've been topping off 2-3 times, and easily have added close to a 1/2 quart of coolant total. If there was a leak, that 1/2 quart of coolant had to be visible somewhere under or around the engine. But it's not. It's All is clean.
Since the level was stable and I found no leaks under the car, I assumed that maybe I had an air bubble somewhere in the system and it got evacuated during the long drive to the mountains.
Well, this morning, after the car has been sitting parked for 48 hrs, (we got snowed in), i cleaned all the snow, looked under the hood, and the coolant level was where i left it 2 days ago (good!!) ... then i started the engine to warm up the car, let it run for 15 min or so.... checked under the hood and the coolant was under the "max" again.
So where is my coolant going if no visible leaks?!?!
Thanks for any ideas!!
