Results 1 to 16 of 16
    Stage 2 Banner Advertiser Two Rings APEXWheels's Avatar
    Nov 03 2021
    Bay Area
    Official APEX Audi A3/S3/RS3 SM-10 Flow Formed 17" & 18" Wheel Thread
    Introducing The APEX SM-10 Flow Formed 17" & 18" Wheel Line
    Engineered Specifically for MQB Based VW & Audi Models
    Introducing our Flow Formed SM-10 wheels, with bolt-on fitments specifically developed for the Audi 8V A3/S3/RS3. These 17” and 18” wheels are offered in both 8.5” and 9” widths to ensure all types of drivers have access to the right wheel fitment for their specific needs. When the team at APEX Race Parts initially reached out to the VW/Audi community with the intention to offer a race-focused wheel line for the MQB chassis, the feature and functionality requests from engaged enthusiasts were overwhelming. We quickly learned there were numerous gaps in the current aftermarket offerings, and as a result, we made it our mission to engineer better wheel solutions for VW/Audi drivers on and off the race track.
    Specifically, there was a demand for an aggressive, strong, and lightweight 17” track-focused wheel line with the ability to clear many of the popular big brake kits that typically forced enthusiasts to use 18″ or 19" wheels. For weekend track warriors and racers, running unnecessarily large wheels meant more weight, less tire sidewall, and higher tire running costs. Leveraging laser scanning and exhaustive on-car fitment testing sessions, our engineers optimized the barrel shape and spoke curvatures of the SM-10 design which allows our most track-focused 17×9” wheel to clear factory S3 brakes, as well as noteworthy aftermarket BBK’s like Essex AP Racing and StopTech 355mm kits. For cars running larger factory brakes, such as the RS3 with massive 8-Piston calipers and 370mm rotors, the 18x9" ET42 offers plenty of breathing room without any need for spacers.
    To learn more about our recommended wheel & tire setups for the Audi 8V A3/S3/RS3 you can browse our chassis-specific fitment guide below:
    APEX Audi 8V A3/S3 Wheel & Tire Fitment Guide
    APEX Audi 8V RS3 Wheel & Tire Fitment Guide
    APEX Flow Formed Wheels
    For over 10 years, APEX has been the go-to wheel for enthusiasts looking for the perfect balance between strength, weight, and cost. Our wheel designs address the concerns of more and more racers and track day enthusiasts: long term durability, fitment, and performance. Specifically, our SM-10 wheel line provides a step-up in strength and true race wheel features like I-beam spokes and reinforced lips.
    ➡︎ Perfect fit without spacers
    ➡︎ Made to work with big brake kits
    ➡︎ 100% OEM compatibility, no extra hardware required
    ➡︎ Unbeatable warranty & 50% replacement program
    Available Finishes:
    Fit Matters
    The right solution for every application. An optimized car setup begins with the perfect wheel and tire fitment. Without model-specific attention to each wheels specifications, maximum performance is compromised. Each size was selected to find the right balance between a clean fit and the most grip possible. Each design's wide range of widths, offsets, and face profiles result in unique fitments. Each wheel combines these features to meet the different brake caliper, strut, and fender clearance needs of each VW/Audi model. Most vehicle models have options for wheels that range from direct-fit to aggressive for specialty applications. Daily drivers and professional racers don't have the same needs, so why should they be forced to buy the same exact fitment?
    100% OEM Compatibility
    No aftermarket hardware required, just bolt on and go. All APEX VW/Audi SM-10s are specifically optimized for the MQB chassis, utilizing a 5x112 bolt pattern, 57.1mm center bore, and OEM spec R13 ball seat lug recesses. This means you won't need to bother with additional aftermarket hardware such as centering rings or conical lug bolts. All wheels come with gloss black APEX center caps, but you can also snap-in your OEM 66mm VW/Audi caps for a more OEM+ look. All APEX wheels accept OEM and aftermarket equivalent TPMS sensors, and any standard-sized metal or rubber valve stem.
    Brake Clearance
    We've made sure our Flow Formed wheels clear OEM steel brakes spacer-free when the correct vehicle-specific designs and fitments are used. With many applications, even big brake kits will clear spacer-free. The 17" SM-10 clears many kits up to 355mm, while our 18" SM-10 clears up to 380mm, including the massive factory 8-piston OEM RS3 brakes, which has been a benchmark as one of the toughest brake setups to clear.
    Weight Optimized
    We conducted extensive Finite Element Analysis to reinforce high-stress areas and to remove material where it didn’t improve strength. The end result is a flow formed wheel with an ideal balance of strength and weight.
    JWL & VIA - More Than Just a Stamp
    Many companies promote their wheels as being certified by the VIA when they actually aren’t. That’s like using the USDA logo on food without permission. APEX flow formed wheels are officially tested and registered by the VIA in Japan, and we have the proof to back it up. Japan’s JWL is a standard for wheel load ratings. Our wheels exceed those ratings. Most manufacturers only meet the minimum, while some even fall below—yet they still claim to be JWL. Always verify load ratings before you buy.
    Paintless Knurled Beads
    Whether it's a day at the track or months of street driving, repeated hard braking and acceleration can make a tire slip along the bead seat and go out of balance, causing vibration. Knurled beads help, but are less effective when painted over. Our forged line features unpainted knurled beads that stay sharp and maximize grip.
    Learn more about why our forged wheels have unpainted knurled beads.
    Built For Impact Sockets
    Track wheels need track tools. Don’t settle for wheels that require undersized tuner lugs or thin walled sockets. All APEX wheels accommodate over-sized race lugs and impact sockets to make swapping wheels lightning fast.
    Lifetime Warranty
    All APEX wheels come with a lifetime structural warranty against defects in workmanship and materials, plus a 1-year finish warranty. Exchanges are fast, easy, and hassle-free.
    Learn more
    APEX Wheel Replacement Program
    Curb rash or pothole damage on the street? Make an oopsie at the track? We’ve all been there. APEX is proud to offer 50% off replacement wheels, no matter the damage.
    Learn more
    A Fitment For You
    We’ve tirelessly test-fitted hundreds of setup combinations in order to provide direct-fit, spacer-free wheel packages for everything from showroom-fresh cars to all-out race builds. Our detailed fitment guides help you avoid costly trial-and-error and walk you through every step of finding your perfect setup.
    Explore our Audi 8V A3/S3 Fitment Guides
    Explore our Audi 8V RS3 Fitment Guides
    Explore our Audi 8J TT RS Fitment Guides
    Explore our Audi FV/8S TT RS Fitment Guides
    Questions?
    Call: 925-245-0773
    Email: [email protected]
    Web: www.apexraceparts.com
    Hours: M-F 9a-5p PST
    Nov 03 2021
    Bay Area
    Reserved
    Nov 03 2021
    Bay Area
    Reserved
    Nov 03 2021
    Bay Area
    Planning to hit the track in your RS3? The Flow Formed SM-10 has you covered!
    This particular 8V RS3 is running a set of Satin Bronze 18x9" ET42 SM-10s wrapped in 265/35-18 Falken Azenis RT660 tires at all four corners. Enjoy!
    Nov 03 2021
    Bay Area
    A new Sprint™ Line design is coming soon.
    Exciting news - the next member of our Forged Sprint line family is on the way!
    Sign up at the link below to be the first to know about fitments, finishes, and Group Buy discounts.
    Upcoming APEX Forged Sprint Line Design
    Nov 03 2021
    Bay Area
    We're one week away to reveal, are you ready?
    Nov 03 2021
    Bay Area
    Introducing the Forged SM-10RS. An ultralight version of our already popular SM-10 design.
    We’re a function-over-form brand, so we took our time and engineered this wheel to be our best. The original SM-10 has been re-engineered with thinner spokes and extra-deep side-milling for maximum weight reduction. The SM-10RS is now our lightest wheel in some fitments and meaningfully stiffer than our popular VS-5RS.
    Just like all Forged Sprint™ Line wheels, the new SM-10RS features:
    Sprint Spec Inner Lip
    Fully Forged from 6061 Aluminum
    Massive Spoke and Barrel Clearance
    Un-Painted Knurled Beads
    Lifetime Structural Warranty
    Unmatched Replacement Program
    Click here for more details and to see a list of fitments for your specific chassis.
    APEX SM-10RS
    Click here to join one of our active Group Buys to get deep volume discounts on our existing VS-5RS and EC-7RS forged wheel designs, or to be among the first to pre-order the all-new SM-10RS!
    Sprint Line™ Group Buy
    Curious about fitment? We've got you covered!
    Nov 03 2021
    Bay Area
    In celebration of Memorial Day, we’re kicking off a sale on our popular SM-10 wheel lines. Whether it be the feature-rich Evolution Line Flow Formed variant or the fully Forged Sprint Line SM-10RS, we’ve got you covered.
    APEX Flow Formed SM-10s: Up to 20% off
    Forged Sprint Line SM-10RS: Up to 10% off
    With Free Shipping and hardware discounted as well, there's never been a better time to buy. This sale ends on June 2nd so don’t miss these discounts!
    Buy Today
    Questions?
    Call: 925-245-0773
    Web: www.apexwheels.com
    Nov 03 2021
    Bay Area
    Our biggest sale of the year is now live! Don’t miss your chance to lock in a deep discount on sets of our Forged and Flow Formed wheels as the holiday season kicks off. All our wheels are on sale with huge discounts available sitewide. Free shipping will also be available for all orders during the sale.*
    Buy Now
    15% off Sprint Line Forged Wheels
    Our popular Forged offerings at an even more affordable price. Save 15% on the lightest wheels we make including our VS-5RS and SM-10RS designs.
    20% Off Flow Formed Wheels
    A better value than ever, our Flow Formed VW/Audi SM-10 wheels are 20% off across the board. With 17" and 18" options in both OEM+ and aggressive track/street fitments available, there's a perfect fitment out there for every car.
    Spacers and More
    Caps, Spacers, Studkits, Bolts, Nuts. No matter what you need to get your fitment dialed in, our sale has you covered with a 20% discount on these critical upgrades for your VW/Audi.
    With a variety of options on offer be sure to consult our Fitment Guides before ordering. If you still have questions, our fitment experts are standing by to help with inquiries, but will be overwhelmed as we near the sale’s end. Beat the procrastinators and reach out early for help with your next set of Apex wheels.
    Buy Now
    Need time before you buy? This sale ends on November 30th at midnight PST.
    *Free shipping to the lower 48 US states
    Questions?
    Call: 925-245-0773
    Web: https://apexwheels.com
    Junior Member Two Rings Redlinez's Avatar
    Oct 15 2023
    Fuquay Varina NC
    I do believe this wheel is at the top of my list for my 24 S3. One of the few I've seen actually installed on this vehicle and it looks right!
    24 S3 PP, sport pack, sport resonator
    Wife's ride: 2023 Audi S4 PP, sport pack
    Nov 03 2021
    Bay Area
    Our largest sale of the year is already halfway over, don’t miss out on these savings. We have all of our Audi wheels on sale at 15-20% off along with Apex accessories like spacers, stud kits, and center caps.
    If you have any questions regarding fitment or other technical wheel/tire details, feel free to check out our Audi fitment guides via the following link:
    APEX Audi Wheel & Tire Fitment Guides
    If you can't find the answers you're looking for in the guides, you can send us a message using our fitment form.
    Buy Now
    Questions?
    Call: (925) 245-0773
    Web: apexwheels.com
    Nov 03 2021
    Bay Area
    Our biggest sale of the year is extended for 24 hours! This is your last chance to lock in a deep discount on sets of our Forged and Flow Formed wheels. On top of huge savings, free shipping will be available for all orders during the sale.*
    With a variety of options on offer be sure to consult our Fitment Guides before ordering. If you procrastinated a bit, that’s okay! Our fitment experts are standing by to help with any questions you may have.
    You can find our Audi-specific fitment guides via the following link:
    Buy Now
    Questions?
    Web: apexwheels.com
    Nov 03 2021
    Bay Area
    Put that refund to work with our Tax Season Sale ongoing now. Save up to 25% off + Free Shipping* on a huge variety of in-stock fitments. Every Sprint Line Forged and Flow Formed wheel we offer is on sale. This sale ends on April 22nd, but discounts apply while supplies last. Get your order in today!
    Apex Flow Formed: Up to 25% off
    Apex Sprint Line Forged: Up to 15% off
    The Lightest Wheels We Make. Deep discounts on all of our Fully Forged SM-10RS and VS-5RS are available making our high-performance lightweight wheels an even better value.
    Apex Accessories: 15% off
    All Apex Studkits, Lug Bolts, and Centercaps are discounted and get free shipping. Get your car ready for the track season today.
    Free Shipping
    All orders of wheels and qualifying Apex accessories will get free shipping* through the 22nd.
    Fitment Guides
    We know what fits. From direct bolt-on to all-out race fitments and everything in between. We've street and track tested extensively to save you the trial-and-error.
    *Free Shipping to the 48 Contiguous States only.
    Questions?
    Call: 925-245-0773
    Nov 03 2021
    Bay Area
    Celebrate Memorial Day with a new set of Flow Formed Apex Wheels. Save 15% off + Free Shipping* on our SM-10 and 10% off + Free Shipping* on our ARC-8 and EC-7 wheels. This sale ends on Friday September 6th so don't miss out and get your order in today!
    Buy Now
    Apex SM-10: 15% off
    Our original ten spoke wheel. Our Flow Formed Evolution line SM-10 design is discounted across the board for a limited time. The Flow Formed SM-10 features I Beam spokes and a reinforced inner lip and brings these forged features to an even more attainable flow-formed price point.
    Buy Now
    Apex Accessories: 10% off
    All Apex Stud Kits, Lug Bolts, Spacers, and Center Caps are discounted and get free shipping. It's not too late to pick up the hardware you need!
    Buy Now
    Free Shipping
    All orders with Flow Formed wheels and qualifying Apex accessories will get free shipping* during this Memorial Day sale.
    Fitment Guides
    View our fitment guides.
    Questions?
    Call: 925-245-0773
    Nov 03 2021
    Bay Area
    Buy Now
    Need additional accessories to go with your new wheels? All Apex Stud Kits, Lug Bolts, Spacers, and Center Caps are discounted 10% and get free shipping.
    Deal still not sweet enough? All orders with Flow Formed wheels and qualifying Apex accessories will get free shipping* during this Memorial Day sale. Hurry, sale ends this Friday September 6th at 11:59pm PST.
    Nov 03 2021
    Bay Area
    Howdy folks!
    We are quickly approaching the launch of our all-new VW/Audi wheel designs & fitments and we are looking for some volunteers local to our office in the Bay Area, CA to assist with on-car photography. At this time, we are trying to track down some lightly modified examples of an 8V RS3, 8V S3, 8Y S3, 8J TTRS, and 8S TTRS that would be available to swing by our office for a few hours to do some on-car shoots around mid-late February. Any volunteers willing to assist would be getting an early "sneak peek" of these new wheels, as well as the opportunity to purchase a set for themselves at a strong discount in exchange for helping us out.
    If anyone local to our office is interested and willing to bring their car by for a few hours, please feel free to PM me here or shoot me an email: [email protected]
    -Geirsen
