Hello everyone, I could really use some help.
I just purchased a 2007 A4 Quattro Cabriolet automatic b7 with 116k miles that has engine problems. The previous owner says it was working fine but then it just stopped and the engine light came on. I checked the codes and these two came up, p0343 and p000a. The engine will crank but not start.
I was originally hoping it would be a faulty sensor or something minor since I saw the timing belt was changed at 96k miles but after doing a compression check that's not the case. My compression readings are as follows:
Cylinder 1 - 0
Cylinder 2 - 100
Cylinder 3 - 60
Cylinder 4 - 0
I then added a cap of oil to each cylinder and tried it again and found that cylinder 1 and 2 stayed at 0, cylinder 2 stayed the same and cylinder 3 went up to 105. Correct me if I'm wrong but since it's a straight 4 I don't think those results look like the timing belt slipped. I called some local mechanics and they all said they only replace the engines since they're too complicated to work on. Is that common practice on these engines or do I just have lazy mechanics near me?
I was hoping I could repair the engine but I'm not a mechanic and not sure what I should do next. I read about doing an air pressure test to see where the leak is and was wondering if that's the next step or if there's something else I should try? Thanks for any help, it's much appreciated. 🙏
