Hello
I've recently lost most of the sound in my car, happened quite suddenly aswell while driving.
I only have working speakers in the front dashboard, not all but a few of them, and when i put my ear on the speakers in the car i can just hear static noise.
I took the doors interior off and took disconnected the big speaker and the small one cause they werent working, the big one worked slightly, it was more static but i could make out the faint music.
I used Ohm on between the connections and both of them were on 3.7-3.8 Ohm, im guessing thats normal?
If the impedance is O.L its broken right?
Also disconnected the AMP and opened it to see if any capacitors were popped or if the circuit board had been fried, but nothing, also 30A fuse wasnt blown either.
i used 20V DC between Brown/red and Brown/blue which were the wiring on the big speaker in the back door right side, and no voltage, so can it be the amp? and how to i easily check?
i checked youtube and they all have equipment i dont have like tone generator or whatever. and i dont have an external power supply to test, only the car.
Im out of ideas what the reason can be, can it really be the wiring or the connections in the Symphony stereo unit?
I have non-BO speakers and unit is a regular Symphony III i think, no MMI or anything.
Anyone experienced a similar problem, or have any idea what other process of elimination i can use.
Sincerely Kevin.
