Page 3 of 3 FirstFirst 123
Results 81 to 114 of 114
  1. #81
    Jul 08 2016
    SF, CA
    I finally got a video
    https://drive.google.com/file/d/1mXA...ew?usp=sharing
    ITs a little hard to hear but you you hear a boom/thump when the (A) auto start re-starts the car engine. I haven't been able to figure out where this is coming from.
    I am using Audio Control LC2i Pro wit GTO auto sensing remote turn on
    I use to have the remote wire to the 12v outlet but it still happened then, even with the remote turn on set to auto sensing it still happens when car does auto start/stop but not every time, so I am a bit stumped.
  2. #82
    Established Member Two Rings FFM's Avatar
    Aug 29 2019
    Bellingham, WA
    Sounds like the fix is to turn off that god awful feature with a tune 😜
    Current: R8 V8 6MT | B9 SQ5
  3. #83
    Jul 08 2016
    SF, CA
    Quote Originally Posted by FFM View Post
    totally would but I am leased lol
  4. #84
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    again you need to tap from somewhere else, no need to take a video you’ve made it clear that it’s your amp turning off and on lol
    before i got an amp with dc offset, I had the same problem tapping from one of the other ignition switched fuses, fixed by moving to a different fuse. can’t remember which one, you’re just going to need to grab a fuse tap and do some trial and error. you’ll eventually find one that isn’t effected by auto start/stop
    also auto start/stop can’t be disabled with software. there’s modules on aliexpress that mimic the auto start stop button presses to keep it permanently off, that’s the only way.
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
  5. #85
    Apr 08 2011
    '21 SQ5 & '16 Golf R
    NoVA
    Cerwin Vega Spare Tire Subwoofer
    Quote Originally Posted by Gunnarrrrr View Post
    It can be disabled through OBDEleven/VCDS but the start/stop is tied to the HVAC controller and when you turn off the HVAC it turns the stop/start back on.
    I ended up going with a kill harness from Amazon.
    iain
  6. #86
    Established Member Two Rings Flint's Avatar
    May 04 2017
    Florida
    So if I code auto start/stop off with Carista, it will come back on if I use the “off” button for the HVAC system or is it tied to the AC on/off selection?
  7. #87
    Veteran Member Three Rings jcoleman_11's Avatar
    Apr 21 2016
    Toronto, ON
    Quote Originally Posted by Flint View Post
    It’s tied to the AC. If you turn the AC off, auto start/stop function will start working again.
    As long as AC is on, it will stay disabled.
    I disabled it with Carista so I speak from direct experience.
  8. #88
    Apr 08 2011
    NoVA
    That is correct. Just buy a single from Amazon instead.
    iain
  9. #89
    Apr 08 2011
    NoVA
    Quote Originally Posted by jcoleman_11 View Post
    That is the opposite of my experience when disabling it with OBDEleven.
    Hitting the HVAC OFF button turned the start/stop back on.
    No one would be doing that coding if you had to turn off the AC to also turn off the stop/start.
    iain
  10. #90
    Apr 21 2016
    Toronto, ON
    I think you misunderstood what I wrote. We’re saying the same thing.
  11. #91
    Apr 08 2011
    NoVA
    That's what I get for reading too fast.
    iain
  12. #92
    Jul 08 2016
    SF, CA
    Hi
    I am trying to replace the Audio Control Lc2i with a Kicker Keyloc but got it somewhat to work better but wanted to make sure the subwoofer OEM positive and negative pin out to the keyloc was not crossed. IE brown wire coil 1 positive, brown white coil 1 negative etc.
    Does any one know what the wiring colors mean on the OEM subwoofer cabling?
  13. #93
    Senior Member Two Rings iampraneel's Avatar
    Feb 28 2018
    Elk Grove
    Quote Originally Posted by siren0001 View Post
    Hi
    Do you have one of my harnesses?
    Plug and Play Aftermarket Subwoofer/Amp Harness
    https://www.audizine.com/forum/showthread.php?t=945999
    Check out my YT page: https://www.youtube.com/prosumergarage Some great content on Cars and Car Detailing.
    2019 RS 5 Sportback - Daytona Gray Pearl w/ Black Leather and Crescendo Red Stitching Interior
    2020 S Q5 - Quantum Gray w/ Black Leather With Rotor Gray Stitching Interior - Premium Plus with Sport Package
    2016 🌮ma TRD Sport - Silver Sky Metallic w/ Black interior - Premium & Tech w/ JBL
  14. #94
    Mar 30 2022
    Virginia Beach, Va
    So, I ended up ordering an LC2i (months ago), then the LC2i Pro smh. Forgot I had ordered the prior. Aside from form factor and easier access to "tuning" (Accubass, Threshold etc), are there any other advantages in going with the Pro for the install?
  15. #95
    Junior Member Two Rings
    Jun 26 2021
    2021 A5 Sportback, 2005 Sequoia
    Waukee, Iowa
    I believe the Pro model will pass a signal down to 20Hz, whereas the non pro version only down to 30Hz.
  16. #96
    Mar 30 2022
    Virginia Beach, Va
    Got it, thanks!
  17. #97
    Mar 30 2022
    Virginia Beach, Va
    Here’s what I have them set to.
    Good stuff! Question, did you actually tune for AccuBASS as per instructions or? Assuming you did, you did so due to experiencing Bass roll-off? If so, about how high (volume) did you start getting roll-off? Thanks!
  18. #98
    Apr 21 2016
    Toronto, ON
    Quote Originally Posted by 4TBBUCS View Post
    Yup, spent probably about 2 hours tuning it.
    It changed so much from one song to another, so I’ve got the gain knob installed in the center console so I can adjust it when needed.
    Bass starts rolling off at higher levels. There’s no number so it’s hard to say, but where the bar is about half way.
  19. #99
    Mar 30 2022
    Virginia Beach, Va
    Nice! Appreciate the info, thanks.
  20. #100
    Mar 10 2021
    MA
    Looks really good.
    I think this is the best non performance mod for this vehicle.
    just adding this little woofer turns the sound system into a different animal.
    2022 SQ5
    CTS Intercooler, Downpipe
    Jackal / M2 Full custom ECU and TCU
    Diamond Audio Subwoofer + 20'' LightBar
    Custom PCV system + Mishimoto catch can
    ABT HAS, ECS Skid Plate, Roc Euro Intake, DashCam
    034 Trans Insert, Turbo inlet, Sway Bars, Strut Brace, HPFP
    Chrome Delete + CF Mirror Caps / Wide Angle Mirrors, Mud flaps
  21. #101
    Established Member Two Rings Hayk's Avatar
    Jul 24 2019
    Boston, MA
    Hi All,
    I am interested in the DASTX12 setup for a B8.5 2017 SQ5 w/ B&O. Can someone outline which items I need to buy? I am having an car audio shop install it.
    Hayk
  22. #102
    Mar 25 2015
    Placer County
    Quote Originally Posted by Hayk View Post
    Hi All,
    Hayk
    wrong forum
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
  23. #103
    Jul 09 2024
    Texas
    That's a clean install of the ACR-1! I assume you had to pull the center console out? Any pro tips you can share?
    Also, looking at your Lci settings, it's hard to tell which direction they are pointed. Are the accubass level, threshold, and bass level are all toward counterclockwise?
  24. #104
    Apr 21 2016
    Toronto, ON
    Quote Originally Posted by davidj43 View Post
    Turn them all the way to minimum, so counter clockwise, and then turn them clockwise until they match the picture. There’s no way I did more than a 180° turn.
    As for the knob install, I was too lazy to pull the entire center console out, so the wire can be seen going from under the rear seat to under the center console.
    I did have to remove the whole shifter/controls portion.
    Once that’s out, the button cover just pops out.
    To make sure I drilled the hole in the perfect spot, I actually put nail polish on the tip of the bare knob, and slid it in the cover, so the nail polish leaves a spot exactly where the knob would poke through, and that’s where you drill.
    The other hole for the LED I just eyeballed. I also had to bend it to fit the button, and also had to break a tab off the button to fit it.
    I hope that helps!
  25. #105
    Mar 30 2022
    Virginia Beach, Va
    Shoutout to @ iampraneel! Appreciate the harness and help! Finally got around to finishing the install. Sounds damn good! Literally the only thing missing (subjective) in the BO system, was this upgrade. System sounds complete now, with plenty of bass for my liking. Install was pretty straightforward, only hiccup was, forgetting to install the remote…which is a must in order to get the sub to work. Knucklehead move on my part smh. Took longer to tune everything to my liking ( couple weeks of tweaking this and that) , than the actual install.
  26. #106
    Veteran Member Four Rings A4Maine-iac's Avatar
    May 03 2010
    2012 TT Sold
    Maine
    Yes that harness was key! I went this route and was very happy. Yes is its about an 1" too thick but i have a cargo matt so you cant even tell. Just need to spend some time tuning it. Think ill have another do that for me. These old ears don't hear like thy used to.
    https://www.amazon.com/dp/B00IIL0LW0...sin_title&th=1
    https://www.amazon.com/dp/B09K39JFFM...fed_asin_title
    2002 A4 1.8T - sold
    2007 DTM S4 -Sold Sound clip - https://www.youtube.com/watch?v=bGz60n-31jc
    2012 TT - TTS Rear & Exhaust- UNI Stage 1+ " More to come"
    2021 SQ5 - " Just getting started
  27. #107
    Established Member Two Rings RWLib3's Avatar
    May 28 2005
    Roseville
    Just a quick note for anyone looking to do this...I used a Kicker 46KISLOAD2 ($40ish - high line in) using Praneel's harness, to a Kicker 46KISLOC ($15 - RCA out). Works great so far! Hasn't cut out once. Both units are very small, and fit nicely into the foam around the spare tire. I started with a Rockville 11" spare tire sub, as I don't want/need a ton of bass, but its more than enough for what I need. May upgrade to the CV at some point though...
  28. #108
    Junior Member One Ring
    Aug 21 2018
    WPB, FL
    Thanks for all the info and pictures in this thread. I have ordered everything including the harness and am looking to get this done this weekend. I think with the pics and info here I will be able to put this together.
  29. #109
    Aug 21 2018
    WPB, FL
    I love this knob install.
  30. #110
    Aug 21 2018
    WPB, FL
    OK, so I pussed out. I had an installer do it even with the premade harness. I was afraid to wire it to power.
    He said I didn't need the LC2I Pro. It did not die out over the 20 minute drive home. I told him if it does I will be back.
    Anyone else do it without the LC2I pro?
  31. #111
    Established Member Two Rings FlakoRevoS4's Avatar
    Apr 08 2014
    2018 SQ5 / 2013 MK6 GTI
    Miami beach
    Has anyone used the main outputs out of the LC2 pro for another amp while using the bass connection as the input as we use it here for the bass upgrade?
  32. #112
    Feb 28 2018
    Elk Grove
    Quote Originally Posted by DC321 View Post
    It typically works fine for a few start cycles then the bass cuts out.
  33. #113
    Feb 11 2025
    PNW
    I am an electrical novice. I purchased everything on Praneel’s list. Does anyone have step by step instructions? What tools will I need?
  34. #114
    Mar 10 2021
    MA
    Quote Originally Posted by Landobourbon View Post
    I think I posted a step by step guide.
    I'm 100000% more of an electrical novice. I thought when I stuck the fuse in on the power wire I was gonna die. I thought when I connected it I was going to die.
    Somehow its still all good.
    Just take your time. Nothing is that hard or is anything you can't do with a little time and a really really really good wire cutter / outside remover.
    Don't be like me and use a lighter to burn off the rubber to make connections. I learned some really bad habits from watching my russian friends do home repair.
    2022 SQ5
