Results 1 to 2 of 2
    Dec 25 2022
    New Turbo C0300 C0700 C0701
    I replaced the turbo in the car and now it will not move in gear. I have these 3 fault codes and cannot find definitive answers as to what they mean.
    C0300
    C0700
    C0701
    Obviously something is going on with the transmission. I am going to change the fluid in the am. I need to identify a starting point for the transmission issue.
    Veteran Member Three Rings Older_not_Wiser's Avatar
    Mar 16 2012
    2006 A4 Quattro 2.0T S-Line Avant Quartz Gray - Project Car
    Lomita, California
    You must be using a generic scanner as these codes do not come up with much for VW/Audi. The 'C' prefix usually indicates the diagnostic code is 'Controller' related.
    It seems C0700 and C0701 can mean different thing for different vehicles.
    Try and find a scanner/software dedicated to VW/Audi like VCDS or ODB-11 they will likely provide more information. Then google 'Code#' Ross Tech and it should give you a place to start.
    2008 A4 2.0T Quattro S-Line Titanium Sedan Phantom Black Pearl - Daily Driver
    2006 A4 2.0T Quattro S-Line Avant Quartz Gray - Project Car
