Results 1 to 11 of 11
    Nov 29 2022
    52' Chev 3100, 66' Pontiac Catalina, LB7 Duramax, 84' FXR,19' Atlas
    Wisconsin
    Problems with Britney
    So I Bought the A4/ B7 a few months back as a commuter as i drive 135 miles a day for work. I had a few issues, things is that were common PCV valve and vacuum leaks,
    So the things Ive done recently,
    Plugs/ Coil pack, PCV & hoses, Throttle body. I did this due the throttle body having a little oil residue and a missing gasket. it threw these codes as well probably a month into driving it. This fixed the issues. Until now.
    Winter shows its face and the water and slush have seem to get into the intercooler. about a full quarts worth. Yeah the hose clamps were loose. So this beautiful mix made its way up to the throttle body and PCV. I flush the entire system of the intercooler. hoses and tube channel. Replaced the PCV and cleaned the throttle body. The residue mix stopped at the PCV. upon further inspection.
    The car is running pretty damn rough now. after cleaning everything out and reconnecting. Threw a few codes:
    P0458 EVAP SYSTEM PURGE CONTROL VAVEL CIRCUIT LOW
    P0245 SOLINOID VALVE (a) FOR BOOST PRES. CONTROL N75
    P0301 cy1 misfire
    p0303 cyl 3
    p0300 multiple cyl misfire.
    I've switched coil packs around to rule those out.
    My only conclusion now is that the throttle body is ruined due to the water/oil that was sucked in from the intercooler.
    & Boost Solenoid Control Valve possibly as well. As a note the TB I purchased first was like 80.00 from Rockauto.
    Thoughts?
    Nov 29 2022
    Wisconsin
    replaced throttle body, found grouding issue, cyl1 cly3 misfire. car still runs like shit. these cars are fkn garbage.
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    Quote Originally Posted by willhannwisco View Post
    ...these cars are fkn garbage.
    Totally disagree - I've had my car since new and with regular maintenance over the years and currently at 212,000km, my Avant runs like new.
    Do you still have the Evap System and Boost Pressure errors? They are different valves than the PCV. Water and slush into the engine is obviously not good but I think you need to be a little more methodical with your troubleshooting. You switched coilpacks around but did you check the spark plugs as well? What's the status of your cam follower and fuel pressure rail from the HPFP?
    Current:
    2017 B9 A4 Technik, 2.0T, 6 spd manual, S-Line, quattro with Ultra
    2008 B7 A4 Avant, 2.0T, 6MTQS, S-Line, Special Edition
    Past: - 2005 B6 A4 3.0 V6 6MTQS, 1998 B5 A4 2.8 V6 5MTQS
    Feb 15 2016
    Cambridge,Ontario
    well.perhaps you can go buy a Toyota, and call it Karen..
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Veteran Member Three Rings xRenesis's Avatar
    Jan 14 2015
    South Dakota
    be pretty hard to destroy a tb by 'sucking in air and oil', pretty well sealed and easy to take apart...
    be funny if you havent pulled the spark plugs and theyre toast
    2005.5 A4 B7 - 2.7t K04 - DTM/S4 OEM+ (My B7 Rear BBK)
    2014 Q5 B8.5 - 3.0t (My B8/B8.5 Rear BBK)
    ig 1red_b7
    Nov 29 2022
    Wisconsin
    I knew I would catch some attention on the junk part. I did change the plugs, that was stated in the 1st post along with coil packs. The cam follower was new as well. Fuel Pressure was perfect. A friend of mine that's a service tech a the VW shop came over and we went through some codes with his PC. Came down to a compression test. Cyl. 1 is the culprit to the issue. Less than 60%. Motor's Fkd. Thinking I may have sucked moisture into the system nothing made past the PCV. When we pulled the plugs that were just installed prior looked like they had 100k miles on them. Junk. 4500 car with 4500 car problems. Didn't even put on 6k miles.
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT, 08 manual Titanium Avant
    frackville, pa US
    I don't get how you "sucked in water" in the first place.
    When you replaced coils, PCV, etc, did you use quality parts? Like a genuine PCV, and coils like Bosch, NGK, genuine, etc?
    Sent from my LM-G710VM using Audizine Forum mobile app
    Jul 25 2019
    Charlottesville, VA
    I'm sympathetic (I understand the frustration) but as annoying as it is it sometimes comes down to "these things happen" when dealing with used cars. In an ideal world you do a compression test prior to buying (I say "ideal" as I understand not everyone wants to go to that level of pre-purchase inspection.) Now conversely if you bought it with pretty darned high mileage I would have done that, or had a shop do it for you as part of a pre-purchase inspection. Anyway hate to be that guy (and no offense meant) if you want anvil-like reliability you'll want a Honda, Toyota or such like.
    Hope you get things resolved or are able to re-coup some of your money.
    Eric
    2015 A4 2.0T Quattro
    Veteran Member Four Rings Gin+'s Avatar
    Apr 16 2015
    CNY Syracuse
    I feel bad for this guy, but there has to be more to this story.
    They're not scared of you. They're scared of what you represent to 'em.
    Nov 29 2022
    Wisconsin
    Sh$t happens is all I can say. a 4500.00 car with 4500 car problems. Ive come down to two options. I found a motor 87k tested and a warranty 2k delivered. Minus turbo alt. ac comp. Just yank off the oold one. New Seals, good once over. maybe 3500-4 out the door. Or Or or... I'm able to full a full engine kit from Audi Germany through some hoops and loops for 5k. Some Assembly Required.. Needless to say I will giving the car to my nephew after the summer. I want to make sure its a decent car for his first. The days of 500.00 Cadillacs with FWD and 502blocks are long over. I've decided to buy a new A5 instead of a banger to drive 500+ miles a week. Fk it.
    Jan 21 2018
    frackville, pa US
    What are you pricing from Audi? A full rebuild kit, short block?? If ya habe the ability/knowledge to rebuild, ya can do it a lot cheaper..
