Originally Posted by
Fresh.S4
expensive? maybe but its the kit needed to solve fuel problems.
unproven? maybe. everyone is too scared to try.
no they cannot make a spacer that incorporates injectors that fits with the oem plastic manifolds. THAT option is reserved for the meth guys + SRM plates
https://sillyrabbitmotorsport.com/3....ategory_id=120
well, that's not how it works - if somebody is asking money for their product, most people would expect that they would show that it does what it advertised. not just fork out some money and then the product ultimately might not do much. Yes, port injection would be nice because it would allow to run full e85 and not mess with mixing, but there's a sneaky suspicion PI kits (and blowers) didn't pick up any steam due to some ecu limitation(s). Particularly, as I was told and understood, ECU's reference map (ip_tqi_ref) it uses to go back and forth between the load and torque, has a torque limit very close to an e40 dual pulley setup. Or we should say, e40 DP setup is on the limits of this reference map. here's this map from some b8.5 rom (columns are load in mg per stroke and rows are engine speed in rpm, values are torque in Nm):
0 60.02 120.03 180.05 230.06 270.07 350.1 430.11 550.14 700.17 850.2 1250.31
512 0 23.219 50.469 77.75 103 125 165.531 210 294 378 460 693.281
800 0 21.594 60 86 106 130 178 219 297 382 463 697
1024 0 20.5 64 90 114 137 185 226 300 384 468 698
1248 0 20.906 66 96 122 141 190 235 305 386 470 698.469
1504 0 21.125 69 100 126 146 198 252 319 387 472 698.469
1760 0 24.969 70 102 130 154 204 260 326 395 475 698
2016 0 28.563 71 105 134 162 212 266 332 403 473 699
2496 0 29.031 72.125 107 138 164 216 272 338 413 484 703.688
3008 0 32.406 74 109 140 165 212 266 339 420 491 710.625
3520 0 34.781 71 111 141 165 213 264 338 419 488 710.656
4000 0 37.281 74.5 112 141 166 218 268 337 420 487
711.656
4512 0 36.281 75.5 112 142 167 217 264 339 424 490
714.375
5024 0 38.188 76.344 114 144 168 218 268 347 428 506
714.094
5504 0 39.969 78.969 114 143 169 217 267 342 426 503
710.625
6400 0 38.531 77.031 113 143 170.5 219 269 341 420 496 700.219
7200 0 38.969 77.531 112.344 142.719 169.125 219.781 270.125 341.969 418 495 693.906
and it's all downhill from here, these are some reference values in some ideal conditions, and this all gets mostly adjusted down. If PI kits could make a lot of a difference power wise (not just be convenient for e85), I'm sure some major vendors on this platform would have released these already. By the same token, this might explain why APR didn't get much power from their supercharger compared to a DP setup. Of course, I might be wrong about this, this is what I have been told. It does seem more plausible to me than all the hopium-filled stuff about the new PI and blower setups, I've been hearing that this platform is about to have a breakthrough for almost all the years I had this effing car.
