Results 1 to 4 of 4
    Dec 27 2022
    Villanova, PA
    2018 A5 3G Audi Connect, MMI options?
    I知 a new owner of a 2018 A5 Convertible. I have an iphone that works well with Apple CarPlay in the car. Are there additional worthwhile options regarding Audi Connect and the Audi MMI app? The car has non-functioning 3G but I have a US Mobile SIM card I could put into the slot in the glovebox but I知 not sure if it would work and if so, if there is anything to be gained by doing so? The dealer said no. Any guidance would be greatly appreciated.
    Veteran Member Three Rings DrGER's Avatar
    Aug 31 2014
    '17 Audi A4Q 6MT CYMC/RJN, '11 VW GOV TDI 6MT CJAA/LHD
    NW OH USA
    Quote Originally Posted by KenA5 View Post
    Your B9 A5 has an MIB MMI system, which is supposed to use an eSIM to provision LTE for Audi Connect and Google Earth/POI search services -- you need to work with Audi directly for that (costly, IMO) subscription service. The SIM slot in the MMI main unit can be configured to provision LTE for the internal WiFi AP/hotspot with VCDS. If your CarPlay behaves well, you might as well stick with that. --g
    2017 B9 A4Q P+ 2.0T 6MT Daytona Gray. Previous: 2014 B8.5 A4Q P+ 2.0T 6MT Monsoon Gray; 2009 B8 A4Q P+ 2.0T 6MT Brilliant Red; 2005 B6 A4Q 1.8T 6MT Cambridge Green; 1995 B4 A90Q V6 5MT Pearl White; 1990 B3 A80Q I5 5MT Crystal Silver; 1984 C3 5000S I5 5MT Montego Black; 1978 C2 5000 I5 4AT Helios Blue; 1977 C1 100LS I4 4AT Signal Green; 1974 B1 Fox I4 4AT Sahara Sand.
    Dec 27 2022
    Villanova, PA
    Thanks for your note. Very helpful.
    Jan 12 2023
    Pakistan, Islamabad
    If your car is equipped with the Audi MMI Navigation Plus system, you should be able to take advantage of additional features through Audi Connect and the Audi MMI app. These services provide things like real-time traffic information, online destination search, and parking information. However, without a functional 3G connection, these features will not be available to you. If you have a US Mobile SIM card, it's possible that you could use it to enable a data connection in the car and enable these features, but I would recommend checking with Audi directly to see if that is a supported option for your specific vehicle.
