Hi,
This is my first post on the forum and i realise this subject has been covered by others.
My ignition key(s) have both slowly developed a problem where you cannot remove them from the dash receiver slot without a large push/pull attempt - sometimes they come straight out and at other times it may take 15-20 go's.
I would appreciate any pointers to the following:
1:If i change the switch do you need to purchase new or can you use the original keys and will they require programming? - two dealers have said yes to both and various members here (and a UK independent) have indicated no.
2:How are the steering column clamshell halfs held together - some pics show a combination of screw holes on the lower half but mine have none and some pics i've seen have two screws at the front which will necessitate steering wheel removal.
3:An independent Audi dealer has told me that he has rarely changed dash switches but has changed a number of steering column locks to cure the same problem.
Any help or advice would be muchly appreciated
Best
Alan
