Results 1 to 21 of 21
    Veteran Member Three Rings a4937's Avatar
    Aug 14 2008
    Ohio%20
    Cam follower replaced, hesitant start ever since
    If it's not warmed up it takes several seconds to start. I think this is my 4th time doing it and haven't had any issues prior. I already went through the process again but no change.
    Sent from my SM-G990U using Audizine Forum mobile app
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT, 08 manual Titanium Avant
    frackville, pa US
    Sounds like something went wrong. Check what your fuel pressures are when trying to start it.
    Do you have a late model(07-08) with rubber inlet hose? If so, do you completely remove hpfp, when doing CF service?
    Sent from my LM-G710VM using Audizine Forum mobile app
    Aug 14 2008
    Ohio%20
    Quote Originally Posted by Jayz691 View Post
    I do have an 07, and I don't remove it all the way. I think I got it just now. Somehow during the process I loosened the connector on the pump instead of the fitting on the hard line. Got all that back where it needs to be so hopefully I'm good to go!
    Thanks for responding!
    Feb 15 2016
    Cambridge,Ontario
    and you didn't have a fuel leak ?
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Aug 14 2008
    Ohio%20
    I did. That's what helped me figure it out. It wasn't horrible, and my gas gauge has always went down faster after a half tank but I got gas Wednesday night and seeing how much I used from a full tank just commuting to and from work yesterday made it fairly obvious.
    Feb 15 2016
    Cambridge,Ontario
    Jesus you are are lucky lol...
    1976 Yamaha XS 360
    Senior Member Three Rings 67Twisty's Avatar
    Jul 11 2015
    North Carolina
    No doubt. Could have been a fireball
    Andy
    ‘17 Q7
    ‘07 Avant 6MTQ
    ‘03 525i Touring
    Aug 14 2008
    Ohio%20
    Quote Originally Posted by 67Twisty View Post
    Would you mind humoring me and explaining to me like I'm five how this could happen? lol
    Jul 11 2015
    North Carolina
    Pretty basic, but if fuel is leaking from a high pressure fuel pump (of even via the low pressure line pre-pump), gas can ignite in the presence of ignition source or heat. While the spark plugs and coil packs are on the opposite side of the head, the fuel could easily migrate over to the hot side of the exhaust manifold and ignite.
    Andy
    ‘17 Q7
    ‘07 Avant 6MTQ
    ‘03 525i Touring
    Aug 14 2008
    Ohio%20
    Thanks, couldn't figure out how it would ignite but that makes sense.
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    Surprised you didn't smell any gas at all with losing as much fuel as you said. I only had a slight weeping from my HPFP and could smell gas as soon as I parked the car in the garage.
    Current:
    2017 B9 A4 Technik, 2.0T, 6 spd manual, S-Line, quattro with Ultra
    2008 B7 A4 Avant, 2.0T, 6MTQS, S-Line, Special Edition
    Past: - 2005 B6 A4 3.0 V6 6MTQS, 1998 B5 A4 2.8 V6 5MTQS
    Senior Member Two Rings PhireSideZA's Avatar
    Dec 31 2021
    Ryobi Lawnmower, 1hp
    South Africa
    Same situation when I discovered that mine was weeping. Tightening my banjo fitting didn’t do squat for my fuel consumption though.
    Perhaps some brands of fuels are more aromatic than others? Some brands here by us have a noticeably stronger petroleum smell than the competition, although that was more of a thing back when we had leaded fuels available
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    So are you guys saying the CAM FOLLOWER job is an extremely dangerous one? Because I'm about to tackle mine soon and have no idea, of course I'll go through a plethora of video instructions but this is making me nervous!
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Sep 28 2007
    @80sGuy - no, it's a straightforward job to replace the follower but obviously because you are removing the HPFP pump as part of the process you have to be very careful handling the fuel lines and confirming nothing is leaking/weeping after the replacement of the cam follower has been completed. The concerns raised during this discussion were because the OP was driving multiple times with what sounded like a lot of fuel leaking - that's when things can get dangerous as heat and gas outside the engine is not really a good situation to be in for the reasons as described by 67Twisty.
    Do things slowly and double check all the fuel connections (even if you haven't loosened anything) before starting or driving. Monitor for fuel leaks a few days after as well just to be sure.
    Current:
    Feb 15 2016
    Cambridge,Ontario
    do NOT over torque the three bolts holding the pump to the timing cover after years of fatigue, those threads strip VERY easily . even hand night holding the shirt end of the Allen key is fine.
    1976 Yamaha XS 360
    Jul 11 2015
    North Carolina
    Those three bolts are torque to yield/stretch bolts and technically should be replaced whenever the pump is removed. Most owners/mechanics reuse them and never have an issue, but that’s why the threads can slip as iceman pointed out. Also good practice to replace the fuel pump o ring whenever it’s out. Cheap insurance to prevent oil leaks.
    Andy
    ‘17 Q7
    ‘07 Avant 6MTQ
    ‘03 525i Touring
    Feb 15 2016
    Cambridge,Ontario
    I would not think those bolts are tty. the threads would never withstand it.
    I thought they were only 11ft lbs or something.
    1976 Yamaha XS 360
    Jan 21 2018
    frackville, pa US
    Theyre not TTY. Tq is only like 8ftlb. I just use a mini ratcheting bit driver, so I can't over tighten them. But good to replace at least every few uses.
    Jan 21 2018
    frackville, pa US
    Quote Originally Posted by 80sGuy View Post
    Its very easy, esp if its an 07-08 with rubber inlet hose. Ya don't have to remove the hose. 17mm crows foot wrench and extension work best for hard line. And just snug the 3 bolts. I put some assembly lube on CF/Hpfp whrn installing.
    Jul 11 2015
    North Carolina
    My bad. I had assumed they were stretch bolts based on the online order note I saw about replacing whenever the pump is removed. Makes sense they’re not TTY since the timing cover is aluminum and torque specs are low.
    Andy
    ‘17 Q7
    ‘07 Avant 6MTQ
    ‘03 525i Touring
    Feb 15 2016
    Cambridge,Ontario
    yup thought so
    1976 Yamaha XS 360
