Results 1 to 16 of 16
    Established Member Two Rings cuerna's Avatar
    Jun 23 2010
    Lubbock, Texas
    A6 C7 secondary air pump question.
    Hi
    I am planning on buying a 2013 A6 3.07 with APR stage 2 , upgraded suspension, well maintained, PCV , thermostat etc done.
    But owner said he got a secondary air injection fault recently, anyone know if this is something easy to fix or better pass of this issue ...how hard is this to replace?
    Jun 12 2019
    MK5 Rabbit 2.5 5spd
    Natick, MA
    Not sure if this is the same issue the car that you're looking at has, if so its fairly involved. I think there may be an extended warranty on certain SAI issues with the 3.0T, search in the B8 S4 forum as well as that's more active than here
    https://www.audizine.com/forum/showt...?highlight=sai
    2016 A6 P+ 3.0T / Aviator Blue Metallic / APR Stage II Single Pulley 93 Octane / BG_SQ5 tcu / MercRacing hx v3 / Hartmann Rotor Reps 20x9 ET40 w/ 265/35-20 PS4S / 0-60 3.56 sec
    Jun 23 2010
    Lubbock, Texas
    Ok 👍. I will check on that forum..thanks!
    Sep 16 2020
    West Michigan
    Do you live in an emissions area?
    It has no effect on drivability.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    If the car is tuned then they will likely deny any warranty claim on the secondary air
    Jun 23 2010
    Lubbock, Texas
    No I don't. I live in Texas.
    Jun 23 2010
    Lubbock, Texas
    Ok. It's a 2013 with more than 120k miles, it won't be under warranty anyway correct?
    Veteran Member Three Rings Vinng86's Avatar
    Jul 20 2018
    Toronto, ON
    From what I've seen, people have mentioned it has to be less than 120k miles/193k kms, though the TSB only mentions it's applicable to 15,000 miles or above. I'd maybe call Audi of America and see if they will cover it, especially if its just slightly beyond the 120k mileage.
    TSB:
    https://static.nhtsa.gov/odi/tsbs/20...53120-9999.pdf
    2014 Audi A6 3.0T Technik(Prestige) S-line w/ Black Optics
    Jun 23 2010
    Lubbock, Texas
    Yeah I will definitely be worth to try and
    see what they say.
    Oct 20 2021
    Bulgaria
    I have the Code from time to time, but won't bother wasting money on that. The only thing it does is adding more air in the cats when the car is cold so it can get better emissions. It is really tedious to clean these and Audi are asking alot of money for it( they have a special Tool that uses Water)
    Jun 23 2010
    Lubbock, Texas
    Ok yeah..it seems odd that they use pressure water to clean carbon build..I guess I can try to replace the secondary pump, doesn't seem very hard to replace and if fixes the issue I'll call it good if comes back might try to take to the shop sometime in the future or get the jhm tune with the SAI delete, which could be silly because car comes with the APR stage 2 already....or just learn to live with it...😏
    Sep 16 2020
    West Michigan
    I'd bet the car will be quicker on the JHM software.
    Jun 23 2010
    Lubbock, Texas
    You think? Faster than APR?
    Audi dealer here said won't cover SAI issue because vehicle has passed 120k miles ( vehicle has 128k miles)...😡
    Sep 16 2020
    West Michigan
    Quote Originally Posted by cuerna View Post
    I would expect that if you had APR did a dragy run, then flashed over APR's software with the appropriate JHM. That the car would perform better.
    Dec 14 2017
    An easy check you can do on the pump is to check resistance and it should measure under 4 ohms. If the pump doesn't function you will get a fault stored for both banks. If the hose has been disconnected from the pump you will also get faults stored on both banks. Very rarely would A6, A7 or even A8 models throw that code. I couldn't tell you why but it was more common to do secondary air cleans on S4, S5,Q5, and SQ5 models. Get the pump checked out and make sure it can be commanded on through an output test. I have personally witnessed people perform secondary air cleans just for the fault to still come back static because they didnt check the integrity of the pump.
    Junior Member Two Rings
    Sep 06 2022
    Ottawa
    Mine has that issue, once I flashed 034 stage 1 test pipe tune and did a cat delete, CEL was gone.
