Results 1 to 6 of 6
    Junior Member One Ring
    Oct 28 2022
    British Columbia, Canada
    Backup camera not displaying correctly
    My backup cam recently stopped showing up on the mmi screen. It still beeps through the stereo as if it's working but it does not display anything. Is there an easy fix or do I need a new one? I am on the factory mmi version.
    Feb 15 2016
    Cambridge,Ontario
    what di you mean beeps through the stereo.
    are you talking about obstacle detection? if so that uses a completely different system with sensors in the bumper . Not related to RVC
    when you put it in reverse does the volume go down on the radio and the reverse lights come on ? if so i would say everything else is working and you have a failure of the camera or associated module.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Had the same issue. This worked for me: Clicky click®️
    Jul 16 2018
    Atlanta
    Best to do a scan and see which DTC you're getting, then perform the appropriate for that DTC.
    Oct 28 2022
    It just started working again today. I guess asking how to fix it was all I needed to do lol
    Veteran Member Three Rings Chillaxin's Avatar
    Mar 28 2018
    Jacksonville FL
    I got the intermittent error with the backup cam in my avant. implausible signal code. My battery capacity was less than 30% read through OBD11. I replaced the battery with a new AGM and have not had the backup errors since. Not sure if it was the fix or I'm just lucky, but something you can look into.
