Results 1 to 11 of 11
    Senior Member Four Rings
    Mar 05 2020
    NewYork
    Have rear tail lights on with front running lights/parking lights? Without headlights
    I want to have the tail lights on when the front DRL are on. So when its still light outside before it gets dark I can leave my headlights off longer. Sitting in a parking lot at night id like to have the rears on without the headlights on. I realize I can hold the brake in the parking lot but I just want them on when the when sitting and im not in the car. Not the brake lights but the running lights.
    Can obdeleven do this somehow?
    Thanks.
    I drive a 2011 Audi A5
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    The stock switch doesn't allow for that combo?
    Senior Member Three Rings MongoMcG's Avatar
    Apr 15 2022
    B8 A4, C2 Corvette, Austin-Healey 3000 BJ8, SN95 Mustang, 36 Ford hot rod truck, A4 B9 S-line, A3 8V
    Michigan
    Quote Originally Posted by NitroViper View Post
    Thanks.
    Don't know of a software hack, but a good, old fashioned piece of hardware will do exactly what you're asking with almost no effort.
    “The Force is strong with this one.”
    My K04X build thread
    Mar 05 2020
    NewYork
    lol, never tried that, im dumb.
    Jul 16 2018
    Atlanta
    "parking lights" (headlights off) vs "driving lights" (headlights on).
    Apr 15 2022
    Michigan
    As are all of us, bud, in many ways.
    Senior Member Three Rings A4B8 2.0tfsi's Avatar
    Nov 02 2017
    Sweden
    Yeah ObdEleven will take care of your request. Easier to program DRL and rears on all the time, then having to turn parkingmode on and off, as you get in and out of your car.
    2012 A4 B8 Avant 6MT F23L Custom Tune 3" 200 cell DP Sachs Performance Clutch
    Veteran Member Four Rings RockJGC's Avatar
    Sep 28 2014
    NY/NJ metro area
    Carista has the option to use the rear taillights as DRLs.
    One change I made with Carista that's pretty cool is to have the front DRLs dim when the turn signal is on. So instead of the default behavior (which is the DRL turning off with the turn signal) or changing it to have the DRL remain on with the turn signal, my car dims the DRL to about 50% brightness only on the headlight that has an active turn signal, then it returns to full brightness once the turn signal is canceled. Looks pretty cool....
    Sep 28 2014
    NY/NJ metro area
    Quote Originally Posted by MongoMcG View Post
    That will work, but it will cause the front DRL LEDs to dim. If he wants to use his taillights as DRLs, there's an option to do that in the software. That way, his front DRLs remain at full brightness along with the tailights being on.
    Veteran Member Three Rings DrGER's Avatar
    Aug 31 2014
    '17 Audi A4Q 6MT CYMC/RJN, '11 VW GOV TDI 6MT CJAA/LHD
    NW OH USA
    Re the OP's original question (Rear parking lights on with DRLs on), would this be enabled permanently in Address 09 Byte 2 Bit 7 (set to 1) ?
    And the DRL brightness change noted by RockJGC (dim DRL with turn signal on), would this be enabled in Address 09 Byte 9 Bit 7 (set to 1) ?
    I also wonder how conflicting coding might affect these (say, DRL off with turn signal on (AKA, wink mode). For reference: https://www.vwvortex.com/threads/a4-...rence.9501572/ --g
    2017 B9 A4Q P+ 2.0T 6MT Daytona Gray. Previous: 2014 B8.5 A4Q P+ 2.0T 6MT Monsoon Gray; 2009 B8 A4Q P+ 2.0T 6MT Brilliant Red; 2005 B6 A4Q 1.8T 6MT Cambridge Green; 1995 B4 A90Q V6 5MT Pearl White; 1990 B3 A80Q I5 5MT Crystal Silver; 1984 C3 5000S I5 5MT Montego Black; 1978 C2 5000 I5 4AT Helios Blue; 1977 C1 100LS I4 4AT Signal Green; 1974 B1 Fox I4 4AT Sahara Sand.
    Sep 28 2014
    NY/NJ metro area
    Quote Originally Posted by DrGER View Post
    I obviously didn't do mine with VAGCOM coding like you're talking about....it was just turned on via Carista, so I'm not sure about directly coding these changes. However, I'm pretty sure I had to leave Wink on in order to enable the dimming w/turn signal.
