    Junior Member One Ring
    Dec 27 2020
    Ontario
    Brake recommendations for S3
    Coming up on a front brake job and flush. Think I’m going to DIY this project but I can’t decide which parts. I enjoyed the stock brakes but I wouldn’t mind something a bit more aggressive. I thought about doing blank OEM rotors and aftermarket pads. Something between performance and reliability.
    My commute is a short blast up the highway; but can also deal with lots of hard/sudden braking. No track days or autoX. Brake dust isn’t a huge concern, I clean the wheels regardless. Wouldn’t mind slotted rotors, but not a huge concern on the look.
    Give me your recommendations!
    Dec 25 2004
    Earth
    Z23 pads. Higher carbon steel rotors.
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Stock or any commodity aftermarket rotor, Porterfield R4S pads :)
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    StopTech sport pads are a great option that I highly recommend. Any decent rotor is fine. Ate, Zimmermann, StopTech, Centric, Brembo, etc.
    2019 SQ5 Prestige
    Veteran Member Three Rings Chaoscreature's Avatar
    May 26 2018
    2018 A3 Quattro, 1995 Porsche 993 C2, 2006 Jetta TDI Special Edition, 1956 Willy CJ5
    Vista, CA
    +2 on Porterfields being great pads. Akebono are also excellent. Heck, Autozone Ceramic pads aren't bad for a street car.
    If your brakes don't feel like they are grabbing early/well enough, make sure your brake fluid is fresh and properly bled and your lines are in excellent condition. It might not be the pads.
    "If everything is under control, you're going too slow" - Mario Andretti
