Results 1 to 8 of 8
Thread: OEM IHI Turbo
    Dec 16 2017
    Oregon
    OEM IHI Turbo
    Going though the garage, needs a home. Replaced by dealer at 50k, pulled by me at 90k. Worked perfect when removed, turbo muffler removed, comes with N75/DV/wastegate, everything but the oil/coolant lines/gaskets.
    $200 shipped.
    turbo 1
    turbo 2
    Junior Member Two Rings
    Jun 16 2021
    New Bloomfield Pennsylvania
    This is for the b8.5 right? Any wastegate play at all?
    Dec 16 2017
    Oregon
    Came from my 2012, but the the turbo was from the 2016 timeframe, if the exact date is important I can pull the service records. No the wastegate is not loose. It does have a little bonus grease and dust on it =)
    Jun 16 2021
    [QUOTE=beatsageo;14879588]Came from my 2012, but the the turbo was from the 2016 timeframe, if the exact date is important I can pull the service records. No the wastegate is not loose. It does have a little bonus grease and dust on it =)[/QUO
    I'm very interested in it, do you mind seeing if your records show the part number? I'm trying to see if it will fit a 2015, I think the turbos changed between the years.
    Dec 16 2017
    Oregon
    records
    part_number
    Unfortunately my dealer print out does not show the P/N but its stamped on the turbo.
    Jun 16 2021
    Quote Originally Posted by beatsageo View Post
    records
    part_number
    I'm not sure if it would techinically work for me. Mine ends in a 703s. I'm currently trying to find the difference between them. It looks like the turbo was changed in 2013 to the 703s
    Jan 20 2023
    North Haven CT
    Interested in buying this. When can you get it shipped
    Dec 16 2017
    Oregon
    Quote Originally Posted by John2011A4 View Post
    Monday
