So I installed raceland ulitmo coilovers last weekend. Yesterday I was adjusting the ride height on the fronts when I noticed my right outer tie rod end wasn't seated all the way in the sleeve.
I went ahead with taking the bolts out, seated it properly, and put everything back together. But now I get a low groan/creaking sound when I turn right at extremely slow speeds or a standstill. It's only a low noise and it doesn't sound bad but if it wasn't doing it before I'd like to at least give it a shot at fixing.
I wonder if I should take the end out again, lube it up, and shove it back in and maybe that'll fix it.
Only thing is I just got an alignment done today. Would taking the tie rod end out and putting it back in mess with my alignment? If that's all I'm doing I don't think it would but I would like a second opinion.
Any help is appreciated, thanks :D
