Results 1 to 13 of 13
    Senior Member Four Rings VMCB5S4's Avatar
    Dec 13 2021
    New Hampshire
    B5 S4 Turbo Oil Return Port Popped Out
    Removed the oil return line from the driver side turbo and everything went well. Attempted to remove the passenger side and pulled the cap out of the port with it (pictured below).
    Attachment 292258
    Attachment 292259
    I've read a few threads that mentioned using some type of epoxy as a sealant and pressing it back in. Is this the best idea? If so, does anyone know what epoxy or adhesive to use?
    I wish there were replacement caps to press in. I can't find them anywhere.
    2000 Imola Yellow S4 l 034 STK l PT6062
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    I put alil sealant on the and shove her back in.
    Dec 13 2021
    New Hampshire
    Quote Originally Posted by Silverex View Post
    Sounds good. What sealant would you recommend?
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    I like Dirko HT.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Nov 13 2018
    Ocean city NJ
    Quote Originally Posted by VMCB5S4 View Post
    Wanna say I used aerobatic sealant like used on compressor housings…if not I used Dirko HT.
    Feb 23 2010
    Emmaus Pa
    That surface looks a little rough for anaerobic sealant. I used that on my compressor housings as well, but those are nice machined surfaces. It may be ok here too if OP cleaned up the insert and bore in the pan.
    B9 S4- EPL/AWE
    Nov 13 2018
    Ocean city NJ
    Quote Originally Posted by CELison View Post
    Honestly can’t remember so maybe I’m wrong and didn’t use it… but I know I definitely spent some time cleaning them. There was like a plastic like coating on them that was starting to chip so I fully cleaned/removed that.
    Dec 13 2021
    New Hampshire
    Thank you both for the feedback. I'm trying to purchase the Dirko sealant from FCPEuro. My cart is filled with parts I need and one of these will put me over $50 so I get free shipping lol. Will either of these work? One is Dirko HT and the other is Dirko Black.
    https://www.fcpeuro.com/products/gas...ealant-1161059
    https://www.fcpeuro.com/products/oil...-elring-006552
    Feb 23 2010
    Emmaus Pa
    I would think either would be ok. I used the HT (red) as my oil pan gasket maker and it's been perfectly fine. I also use it for VCGs and anything someone would use RTV for.
    B9 S4- EPL/AWE
    Dec 13 2021
    New Hampshire
    Ok great. I went ahead and grabbed the HT Grey since it's the highest temp rating. I need to swap driver and passenger valve covers. Got a set of Elring valve cover gaskets and this stuff will assist with that job too. Thanks!
    Dec 13 2021
    New Hampshire
    Just realized I didn't buy a second drain flange. So... the 22mm drain flange works on the driver side with the cap (sleeve) still installed. I measured the passenger side drain flange port with no cap (sleeve) and got 24mm. Does this mean I could use the 24mm drain flange below in that port or do I need to reinstall the sleeve for proper operation and buy a 22mm drain flange?
    https://www.034motorsport.com/drain-...n-to-10an.html
    https://www.034motorsport.com/drain-...arge-24mm.html
    Dec 13 2021
    New Hampshire
    Thank you for this info. Doesn't quite answer my question above but helps as far as sleeve install goes. I'm going to proceed with reinstalling the cap and grabbing a 22mm drain flange from 034. These flanges are more of a permanent option compared to stock drain lines.
