Results 1 to 12 of 12
    Oct 14 2016
    Florida
    Odyssey AGM49 H8 VCDS size coding
    Hello, i am replacing the stock battery and installing the Odyssey battery.
    The battery AH is 94.
    The VCDS battery adaption size, there is no 94ah on the list. The closest either 93 or 95 AH.
    Which AH size should I selected 93 or 95ah?
    Thanks
    2016 Audi S6
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    Select 93. Chose the closest aH size without going over.
    18 S6
    Oct 14 2016
    Florida
    Got it, thanks !
    2016 Audi S6
    Dec 13 2022
    Rochester NY
    Just bought the same battery. What did you enter for manufacturer (doesn't show EnerSys or Odyssey as an option)
    and the serial number. There's no sticker with it on there.
    Oct 14 2016
    Florida
    Reuse the old vendor code and change the last 2 digits of the serial number.
    2016 Audi S6
    Feb 08 2023
    Ohio
    Quote Originally Posted by chingwongfu View Post
    Put “unknown” for manufacturer if it isn’t listed. Put the serial # that should be on the battery for the serial # as it should be the same number of characters as the BEM code.
    Oct 14 2016
    Florida
    Quote Originally Posted by Kfumes View Post
    Odyssey batteries have no BEM code.
    2016 Audi S6
    Feb 08 2023
    Ohio
    Quote Originally Posted by turbostang View Post
    I just got a battery from costco (no BEM code) and the serial # on the side of the battery was the same amount of numbers/characters as the prior battery BEM code (also in same order of # and letters as prior BEM code). So I just used that.
    Aug 14 2019
    Tampa
    Just change the last digit of the field when you're in VCDS. The number just needs to change.
    18 S6
    Feb 08 2023
    Ohio
    Quote Originally Posted by Audisthesia View Post
    It’s not an issue that I put the serial # of the battery is it? I did take a picture of the old code prior to changing it.
    Aug 14 2019
    Tampa
    No, it's perfectly fine. The number just needs to change so the vehicle knows it's a new battery.
    18 S6
    Veteran Member Three Rings IHave2Turbos's Avatar
    Aug 17 2015
    the only important coding value that matters is the field for battery type. AGM so the BEM charges it properly.
    C7.5 S6
    Mods : OEM+ Stage3 / DS1 ECU / SRM TCU / CTS HX
    B8 A4
    Mods : HPA\\\ K04 / Manifold / HFC / Tune | CTS FMIC / DP | CR-15 | ECS Inserts
    Retrofits: MMI3G+ / RVC / AHH / Color DIS / Cruise Stalks
