Results 1 to 10 of 10
    Veteran Member Four Rings Peter07's Avatar
    May 27 2013
    2005 B6 USP,Mazda 3,q5,
    Chicago IL US
    B6 Manual transmission fluid
    What fluid for manual transmission,Ecs Tuning shows me two types,and how much should i buy it
    G052911A2
    G055532A2
    Which one fits 2005 a4 b6 1.8t q. 6speed
    Transmission code GJW. 02X
    Sent from my SM-G960U using Tapatalk
    AKA: Piotr
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    I would recommend Ravenol Gear Oil MTF-2 75W-80 GL-4 over the factory gear lubes. From my notes ETKA calls out G055532A2 for the 02X GJV. I have run both OEM lubes and the Ravenol has been the best for shifting and reducing driveline shudder. Should take 3.5 liters.
    Jan 01 2012
    2004 A4 Avant
    CO
    part number ending in 11A2 is listed as GL-5 fluid which should only be used in the rear diff. I never like to assume so I would confirm with a dealer that part number ending in 32A2 is GL-4 spec which is what you want for the transmission.
    | 2004 A4 Avant | Gloss Dark Grey |
    | 2.7t K04 swap | 034 RSB | Apikol snub | 17z BBK |Vogtland GT1 Coilovers | Moog adj. UCA's | Peeler reps |
    | 2011 A4 Avant | Brilliant Black | 6MT swap | APR S2 | APR Downpipe | Vogtland Coilovers | RSE's | 034 Sway/tranny mount | Q5 brakes |
    Mar 28 2015
    Quote Originally Posted by jjvwg View Post
    GL-5 is an API gear lube spec. The factory oil is not based on an API spec. It's also factory developed to work in manual transmissions, it even says that on the label.
    Jan 01 2012
    2004 A4 Avant
    CO
    Quote Originally Posted by Kevin C View Post
    Audi may not label their fluids per spec but I would be willing to bet they follow them as they specifically call for a GL-5 rated fluid for the rear diff in the factory manuals. That being said, and ECS tuning could very well be incorrect in their labeling, but the factory manual calls for the 11A2 part number for the 02X. Regardless, pretty much across the board, lube manufacturers say to use GL-4 fluid only in the transmission because it is friendlier to the softer metals used in the synchros and gear selector arms.
    Jun 12 2014
    2002 Audi A4Q (B6) 3.0 6MT; 1999 Mustang Cobra; 2003 G35 Coupe 5AT
    Tampa FL
    Amsoil
    Mar 28 2015
    API stands for the American Petroleum Institute. Good to reference their gear oil rating if its a simple hypoid rear diff for the US market. However, the transaxle has synchros and hypoid gears all using the same lubricant. Using an oil that is tested for very specific conditions that only a subset applies to the transaxle makes absolutely no sense. Audi works with their suppliers to develop the factory fill lubes when they develop the transaxle. They may refer to standard tests but those are most likely not API specific (A good example of lube tests) https://www.swri.org/industry/lubric...fluids-testing
    Things to consider: The wear surfaces of the synchros on the 02X are all faced using the Borgwarner developed carbon facing so the micro pealing of the face from high EP additives is not an issue. Fork faces don't have as severe loading as the cone clutches (not sure of the material)
    As far as the O2x goes:
    The Bentley manual, SSP 325 and various sites call out G052911A - this is the lube that I see some vendors listing as GL-5
    ETKA calls out G055532A2 for the (GJV 02X 2004-2005 A4 six speed)
    G052911A is a bit more expensive and uses a Thiadiazole EP agent. That EP additive is considered to have better corrosion protection to brass while providing good gear protection. My take is this is the higher performing lube of the two PN's, according to ETKA both are listed as compatible both are listed as transmission fluids and not for the rear diff.
    So far of the four gear oils I have tested (G052911A, G055532A, Redline MT-90 ) I would strongly recommend Ravenol Gear Oil MTF-2 over the Redline or either factory gear lubes (OG Approved!).
    O2X Info: SSP http://www.vaglinks.com/docs/ssp/VWU...Assemblies.pdf
    https://www.widman.biz/uploads/Transaxle_oil.pdf
    Also, on early manuals that may not have faced synchros EP additive level may be more of an issue.
    Another good read: https://www.audizine.com/forum/showt...identification
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Ravenol would be my recommendation. Inexpensive, meets all VW specifications and it just plain works: Clicky clickŪ️
    Hi Kevin!
    May 27 2013
    Chicago IL US
    Thank you for your extensive comments. Yesterday I ordered 4 liters of G055532A2, according to the specification of my vin number, it was also confirmed by the Audi dealer I called.
    AKA: Piotr
    Jan 12 2020
    NA
    Hi Kevin!
    I second Ravenol, I changed it before we got these nasty low temp days. It's been nothing but perfect even in -20 days. I'll use this in all of my rigs, it's amazing.
