Results 1 to 12 of 12
    Junior Member One Ring
    Jul 04 2022
    Malaysia
    ABS module error P1653
    I have an S5 4.2 V8, year 2009 B8 model. Had my ABS module fail, recently sent it for a rebuild initially had a low voltage supply error but after rebuilding everythings gone but the errors below still appear, we found the wiring's deteriorating and rewrapped them, have checked battery voltage and health is ok, fuses look ok but not sure which exact fuse to check for the ABS units, anyone knows which one is it? everything else looks ok. Been stuck on these errors for months now and can't get rid of the error and the traction control and ABS warning light beeps up when starting the car and lighting up. Any ideas or anyone had this issue? Below is from my OBDeleven reader.
    01 Engine
    System description: 4.2l V8/4V
    Software number: 8T0907560M
    Software version: 0003
    Hardware number: 8T0907560
    Hardware version: H10
    Long coding: 01140003190F0120
    Trouble codes:
    P1653 - Read DTC memory of ABS CM Upper limit exceeded
    static
    Priority: 2
    Frequency counter: 1
    Driving cycle: 255
    Mileage: 64240 km
    Date: 2008-08-18 03:41:03
    P1653 - Read DTC memory of ABS CM Implausible signal
    static
    Priority: 2
    Frequency counter: 4
    Driving cycle: 255
    Mileage: 64240 km
    Jul 16 2018
    Atlanta
    If you have OBDeleven, do the scan, find the history log, open it or email it and post the actual complete scan log text. The DTCs say check DTCs from ABS but all you post are DTCs from engine.
    Jul 04 2022
    Malaysia
    Quote Originally Posted by Smac770 View Post
    here's the full txt file i checked from the history, under brakes it says low voltage supply, i erased that and it didn't show up again after that last scan. Strange or could i be wrong, it points to two wires below the abs.
    OBDeleven vehicle history log
    Date: 2023-01-04 15:05
    VIN: WAUZZZ8T69A041334
    Car: Audi S5
    Year: 2009
    Body type: Coupe
    Engine: CAUA 260 kW (360 HP) 4.2 l
    Mileage: 64240 KM
    Fault
    Control unit: 01 Engine
    Active faults: 0
    Inactive faults: 4
    Faults:
    static
    static
    P2006 - Intake Manifold Runner Control Bank 1 Stuck Closed Implausible signal
    static
    P2007 - Intake Manifold Runner Control Bank 2 Stuck Closed Implausible signal
    static
    Mileage: 64240 km
    Date: 2022-12-16 18:23
    Fault
    Control unit: 02 Transmission
    Active faults: 0
    Inactive faults: 0
    System description: 0B6 42 FSIRdW
    Software number: 8K0927158E
    Software version: 0020
    Hardware number: 0B6927156
    Hardware version: H04
    ODX name: EV_TCMAL651
    ODX version: A01004
    Faults:
    No trouble codes found
    Mileage: 64240 km
    Date: 2022-12-16 18:24
    Fault
    Control unit: 03 Brakes
    Active faults: 0
    Inactive faults: 2
    System description: ESP8 quattro
    Software number: 8K0907379AF
    Software version: 0210
    Hardware number: 8K0907379AF
    Serial number: --------------
    Faults:
    01200 - ABS valves voltage supply
    static
    01486 - System function test activated
    static
    Mileage: 64240 km
    Fault
    Control unit: 05 Keyless System
    Active faults: 0
    Inactive faults: 0
    System description: BCM2 1.1
    Software number: 8K0907064BP
    Software version: 0246
    Hardware number: 8K0907064BP
    Hardware version: H90
    Faults:
    Mileage: 64240 km
    Fault
    Control unit: 06 Passenger Seat
    Active faults: 0
    Inactive faults: 0
    System description: MEM-BFS
    Software number: 8T0959760B
    Software version: 0043
    Hardware number: 8T0959760B
    Hardware version: H09
    Serial number: 00001001217805
    Faults:
    Mileage: 64240 km
    Fault
    Control unit: 08 Air Conditioning
    Active faults: 0
    Inactive faults: 0
    System description: KLIMA 3 ZONEN
    Software number: 8T2820043T
    Software version: 0150
    Hardware number: 8T2820043T
    Hardware version: H06
    Serial number: 01230120090300
    Faults:
    Mileage: 64240 km
    Fault
    Control unit: 09 Central Electrics
    Active faults: 0
    Inactive faults: 0
    System description: BCM1 1.0
    Software number: 8K0907063D
    Software version: 0253
    Hardware number: 8K0907063D
    Hardware version: H22
    Serial number: 00000000305346
    Faults:
    Mileage: 64240 km
    Fault
    Control unit: 0E Media Player
    Active faults: 0
    Inactive faults: 0
    System description: CDC-MP3-Pana
    Software number: 4E0910110L
    Software version: 0050
    Hardware number: 4E0035110A
    Hardware version: H47
    Faults:
    Mileage: 64240 km
    Fault
    Control unit: 10 Parking Assistance
    Active faults: 0
    Inactive faults: 0
    System description: PARKHILFE 8K
    Software number: 8K0919475G
    Software version: 0040
    Hardware number: 8K0919475A
    Serial number: 40040902607195
    Faults:
    Mileage: 64240 km
    Fault
    Control unit: 15 Airbag
    Active faults: 0
    Inactive faults: 0
    System description: AirbagVW-AU10
    Software number: 8K0959655B
    Software version: 0410
    Hardware number: 8K0959655B
    Hardware version: H27
    Serial number: 0038JD1DPP2N
    ODX name: EV_AirbaECUVWAUDI010
    ODX version: A02007
    Faults:
    Mileage: 64240 km
    Fault
    Control unit: 16 Steering Column
    Active faults: 0
    Inactive faults: 0
    System description: Lenks.Modul
    Software number: 8K0953568F
    Software version: 0013
    Hardware number: 8K0953568F
    Hardware version: H13
    Serial number: 90319HJQ0005Y
    Faults:
    Mileage: 64240 km
    Fault
    Control unit: 19 Gateway
    Active faults: 0
    Inactive faults: 0
    System description: GW-BEM 4CAN-M
    Software number: 8T0907468P
    Software version: 0095
    Hardware number: 8T0907468K
    Serial number: 4600E0912282EB
    Faults:
    Mileage: 64240 km
    Fault
    Control unit: 36 Driver Seat
    Active faults: 0
    Inactive faults: 0
    System description: MEM-FS
    Serial number: 00001001218431
    Faults:
    Mileage: 64240 km
    Fault
    Control unit: 42 Driver Door
    Active faults: 0
    Inactive faults: 0
    System description: TSG FA
    Software number: 8K0959793D
    Software version: 0250
    Hardware number: 8K0959793D
    Hardware version: H11
    Serial number: 0000008397669
    Faults:
    Mileage: 64240 km
    Fault
    Control unit: 46 Comfort System
    Active faults: 0
    Inactive faults: 2
    Serial number: 0116311700
    Faults:
    01134 - Alarm horn Faulty
    static
    00230 - Transmission park selector switch Implausible signal
    static
    Mileage: 64240 km
    Fault
    Control unit: 47 Sound System
    Active faults: 0
    Inactive faults: 1
    System description: DSP Prem
    Software number: 8T0035223H
    Software version: 0120
    Hardware number: 8T0035223H
    Serial number: 34880004303803
    Faults:
    00871 - Right front bass speaker Open circuit
    static
    Mileage: 64240 km
    Fault
    Control unit: 52 Passenger Door
    Active faults: 0
    Inactive faults: 0
    System description: TSG BF
    Software number: 8K0959792D
    Hardware number: 8K0959792D
    Serial number: 0000008381141
    Faults:
    Mileage: 64240 km
    Fault
    Control unit: 53 Parking Brake
    Active faults: 0
    Inactive faults: 0
    System description: EPB Audi B8
    Software number: 8K0907801F
    Software version: 0070
    Hardware number: 8K0907801F
    Serial number: 00000000300567
    Faults:
    Mileage: 64240 km
    Fault
    Control unit: 55 Headlight Regulation
    Active faults: 0
    Inactive faults: 0
    System description: Dynamische LWR H01
    Software number: 8K5907357
    Software version: 0010
    Faults:
    Mileage: 64240 km
    Fault
    Control unit: 56 Radio
    Active faults: 0
    Inactive faults: 0
    System description: Radio U Basic
    Software number: 4F0035053B
    Hardware number: 4F0035053
    Hardware version: H44
    Serial number: 341AI097540405
    Faults:
    Mileage: 64240 km
    Fault
    Control unit: 5F Multimedia
    Active faults: 0
    Inactive faults: 1
    System description: H-BN-EU
    Software number: 8T2035666D
    Software version: 0047
    Hardware number: 8T2035666
    Hardware version: H64
    Serial number: 344AT097512297
    Faults:
    01043 - Control module: Incorrect Software version
    static
    Mileage: 64240 km
    Jul 16 2018
    Atlanta
    I forgot OBDeleven withholds freeze frame data unless you pay them the $50/year for PRO.
    Read DTC memory of ABS CM (control module):
    Upper limit exceeded & Implausible signal
    don't really seem to go with
    But we have no freeze frame data to know fault timestamp or fault frequency or such.
    http://wiki.ross-tech.com/wiki/index.php/01200
    Note the last statement, no idea if it's relevant to the Bosch ESP 8 unit in our cars. But if the code didn't come back after several drives, then the DTC is no longer relevant.
    If you clear the DTCs for 03-Brakes, do they go away or come back? If they come back, you probably need to start there. But it sounds like you've done that? Sometimes it takes several code clearing cycles to fully eliminate these secondary DTCs. Did the other DTC in 03-Brakes come back?
    It could be something in 03-Brakes did set, tripped the DTCs in 01-Engine, but then self cleared on the 03-Brakes side.
    Jul 04 2022
    Malaysia
    i cleared the dtc's in brakes and it didnt come back, but the dtc in engine couldnt be cleared, it just says cannot be erased and just stays there, havent driven the car yet probably gonna go drive it around today to see if any pops up again, im still suspecting the wiring but my mechanic keeps sayings hes checked all wiring looms.
    I'll try to get a freeze frame what does that actually say anyways?
    Jul 16 2018
    Atlanta
    "cannot be erased", that's odd. Never gotten that with VCDS.
    A VCDS example of P1653: https://www.audizine.com/forum/showt...S5-error-codes
    An old version of VCDS and probably not a HEX-V2 cable so no extended freeze frame data. But enough to see at the time of the DTC, the recorded voltage was excessively low. But the guy never came back and concluded his thread, that the DTC cleared after sufficient time with a new battery. He truncated the log, but we see from the header that 03-Brakes had no errors to display. So like yours, what are the 01-Engine DTCs hanging on to?
    https://forums.audirevolution.net/t/...ed-codes/16502
    implies the DTC can be errant when other errors persist. You have other 01-Engine errors in your log, about the manifold flaps, "implausible signal". You might look to mitigate these DTCs and see if then the ABS ones will clear (ie, no errors present to perform full clear, otherwise full clear aborts).
    Jul 04 2022
    Malaysia
    The engine manifold flaps error has been there for a while, the abs error wasn't around until we had to replace the steering rack, then everything just went haywire.
    Jul 16 2018
    Atlanta
    The rack itself wouldn't be involved, unless a plug got swapped; know one case where a guy put the Servotronic plug on something else and the something else on the Servotronic (the plug on the rack).
    Got me. The error messages are not informative enough on their own to speculate what they are trying to say, or even what tripped them.
    Did the system function test error go away too? http://wiki.ross-tech.com/wiki/index.php/01486
    Jul 04 2022
    Malaysia
    yeap all gets erased except for the two below from the engine section:
    Faults:
    static
    static
    Which points to the abs control module(which i've already sent for a rebuild), wiring harness (checked by my mechanic that says he's rewrapped all of it, but im still suspecting the wiring, or battery (which checks out fine otherwise i would've had a whole lot more errors popping up if the battery isn't healthy) or fuses (again mechanic says it checks out fine)
    we did try a used ABS from the breakers with the same exact code numbers, that was worse off, the error showed no communication at all and i returned it. Do you know which fuse goes to the ABS in the S5 models or diagrams that the pins goes to?
    Anything else i can try using the OBDeleven reader? I've upgraded to the pro account now, my mechanic's sure that the ABS module is faulty but i still don't think it is otherwise i would've had other errors coming from the ABS and not that one error.
    Jul 16 2018
    Atlanta
    The messages are from the engine control module, saying there's an issue with the brakes control module. But the scan says there's no issue reported by the brakes control module. So why is the engine control module running around crying wolf about a completely different control module?
    The ABS fuse is the large one under the dash behind the headlamp switch, next to the term 15 relay.
    Is this also you? https://www.a5oc.com/threads/abs-low...iagram.178615/
    Which they had clicked on freeze frame and gotten some actual details about the DTCs. P codes alone are only a starting point, and can be misleading without the details.
    An example of a P1653 from VCDS:
    http://www.audiklub.org/forum/viewto...p?f=1&t=147592
    Notice I can see the timestamps of the P1653 and the ABS error are the same, and I have fault frequency values. But all that matters in that instance is his voltage is too low. Under 12.0V, all bets are off and you need to fix the voltage issue before caring about anything else.
    It could well be whatever the ABS is setting clears on power off; some DTCs do that. You'd need to scan once the issue occurs before turning the engine off.
    https://www.reddit.com/r/Audi/commen...eakout_nobody/
    Another B8.0 S5 with P1653 problems. But he has an actual ABS DFCC listed.
    Jul 04 2022
    Malaysia
    >> seems like his issue isn't solved either. im hoping its the wiring harness.
    Yeap this is me too that pic was from my mechanic's reader, didn't realise he had a freeze frame, should i ask him to click on those and see what it says and post it back? Thanks a lot this helps a lot my gut tells me its the voltages.
    Is this also you?
    Sep 06 2024
    Anon
    Were you ever able to fix this issue? Currently am experiencing the exact same thing with my 2009 S5 4.2l. Replaced my ABS module and still am receiving the same codes as you
