diagram:
https://www.jimellisaudiparts.com/sh...uct=5603653#12
*Of course confirm for your setup via that link. Full parts numbers are below the diagram. Looks like you need:
Drier: need 4E0260749C (x2) .. same for inlet and outlet (#13, #40)
Condenser: 8E0260749D (#31) and 4E0260749A (#30)
..for newbies seeing this, I'd *strongly* recommend buying Audi OEM o-rings. OEM = no leak. Non-OEM o-rings = big risk of leaking. Backed up at least in my experience replacing the compressor 2.5 years ago. Still zero issues. For example, at the drier, p/n: 4E0260749C has dimensions of 16.2mm x 2.5mm. (can't recall if that's OD or ID x thickness) Unless you're confident you have an o-ring matching that size to the 0.1 mm or less, probably a big chance of rework. I despise rework.
..and if you're replacing the compressor, don't forget you'll need a/c refrigerant oil. Pretty sure this is what I used for my compressor, but confirm for your specific model - DENSO p/n 9990101 (OEM brand..p/n: G052300A2 )
