Unfortunately I've got to let this car go. Trans is dead and I don't have the space/time to do a manual/auto swap. It will go into reverse and into limp mode with "drive" selected. This would be an amazing base for someone looking for a manual S6. I've done almost all preventative maintenance that is required on a high mileage engine. Paint is in great shape, bumper needs work (faded) and as you can see in the pics I clipped a wall not long ago on the rear wheel arch. Nothing a PDR guy couldn't fix in a couple minutes. Car exterior is dirty/dusty in the pics and I apologize but its winter here and hoses are currently frozen! Car comes with all associated paper work and manuals.
Below is a list of the work Ive done:
-Oil change with Liqui Molly Leichtlauf every 5k
-181k TB Service, water pump, t-stat, Acc belt and pulleys, coolant reservoir, spark plugs, oil cooler pipe and gasket, trans fluid change and filter
-182k Tie rods, rear break calipers, CCM, SS brake lines
-183k All front control arms, drive shaft carrier, front calipers, front rotors and pads, brake fluid flush
-185k Fuel filter
-187k Rear rotors and pads, Biltsein struts x4, upper shock mounts
-190k Cam chain tensioners, air filter, rear hub carrier bushings
-191k Both front knuckles, front wheel bearings
-195k Valve cover gaskets and ceramic coat (yes, I coated the car a week before the trans died, FML)
Drivers side Cat is rattling, I have an o2 sensor bung/mini-cat in there now so it won't throw a code (it hasn't yet).
No engine related codes are present, obviously there are a few for the trans.
Vehicle is located near 60402 IL
Asking $3800
I'm sure there are some things I forgot to list and will try and update as I go through my notes.
I'd love to sell this to someone here so I don't have to deal with the shitshow of FB!
