Results 1 to 7 of 7
    Junior Member One Ring
    Feb 23 2016
    Michigan
    RSNAV for Q5 with MMI
    Hello, looking for an RSNAV with 10.25" screen. Needs to work with a Q5 MMI version.
    Dec 30 2017
    Norf
    these units have been plaaaaaaaagued with problems since the S4 came out. Even if you got an S3 unit if you had to do a firmware update it would likely brick itself.
    the facebook group should be enough to scare you out of that idea.
    and buying the S4….. not ideal either.
    great units, but wow are they are pain in the arse.
    Veteran Member Four Rings ILVTRANCE's Avatar
    Dec 19 2012
    New York
    Quote Originally Posted by SlingshotSQ5 View Post
    stop talking from your rear end. S3 is near flawless. S4 has some issues but with time I'm sure they will be addressed as all issues are. I have never ever heard of any one bricking their S3 unit. I have flashed f firmware at least 3 times as well and hundreds of others with no issues. . The facebook group is a TECHNICAL SUPPORT GROUP. Yes, you will see people posting issues while a majority will not post about how amazing it is.
    2014 SQ5 P+ | 034 Stage 2 ECU + TCU | 034 190mm crank pully | 034 Street Density motor mounts | 034Motorsport S34 Carbon Fiber Intake | Merc Racing HX V3 | Bilstein B8's w/ H&R Springs | 034 Trans insert | RSNAV 10.25
    NEW EDM MIX APRIL 2021 https://soundcloud.com/matt-scheinwa...in-my-basement
    Jun 25 2019
    Ottawa/Ontario/Canada
    Try an inav unit from 4x4shop.ca. They start at $400usd.
    Feb 23 2016
    Michigan
    bump
    Feb 23 2016
    Michigan
    Quote Originally Posted by dkb7 View Post
    i'll check them out as well...i just like the support system that is there for RSNAV, anyone know if INAV has a good one if there are issues?
    Jun 25 2019
    Inav has internet support. So far they get back to me within the day.
