Conversation has already started above with my post about piston rings...
Depends how long you want to keep the car.
Depends how much you want to spend $$$
The issue with the E888.3 appears to be the original version piston rings. So much so VW/Audi have updated them to fix the issue...
Set of new Mahle 82.5mm E888.3 pistons: $800.
https://www.us.mahle.com/media/usa/m...en-iii-web.pdf
Cost to install?
I can DIY it so just time for me and a new head gasket set and upgrade to head studs and new valve guide seals.
My current engine is at 175,000 miles. I would rather bore it out to accept 83mm pistons.
Refresh all the bearings...did the same on my B6 2004 A4 which is still driving at 326,000 miles.
Used motors every where as the 2.0T is in various models even Porsche Macan.
I found a used 2.0t with 3000 miles for $3500 at a salvage yard. Buy this DIY install it in my S3. Should be good for another 175,000.
What year S3 motors have the updated pistons from the factory? E888.3B?
Many variables...all dependent on individual needs, skills and finances.
