Results 1 to 19 of 19
    Stage 2 Banner Advertiser Two Rings APEXWheels's Avatar
    Nov 03 2021
    Bay Area
    Official APEX Audi A3/S3 VS-5RS Forged 17" Wheel Thread
    Introducing The All-New APEX Forged Sprint Line
    Engineered Specifically for MQB based VW and Audi Models
    Introducing the APEX VS-5RS, our most track-focused VW/Audi wheel yet! The 17x9" ET42 VS-5RS was specifically engineered for MQB-chassis VW/Audi models with the intention of creating a strong and lightweight forged wheel in an aggressive, track-focused fitment. Weighing in at just 16.9 lbs, the 17x9" ET42 VS-5RS offers the perfect solution for any VW/Audi enthusiasts looking to improve their lap times by shedding unsprung weight. With a robust 1,500 lb load rating and a strong reinforced inner lip, you can be confident knowing your wheels will withstand the abuse of repeated track days and autocross events season after season. Utilizing an MQB VW/Audi specific 5x112 bolt pattern, 57.1mm center bore, and OE R13 ball seat lug recesses, the VS-5RS offers a complete plug-and-play fitment. No need for any additional aftermarket hardware, such as conical bolts or centering rings. Just mount and go!
    To learn more about our recommended wheel & tire setups for the 8V Audi A3/S3, you can browse our chassis-specific fitment guide below:
    APEX Audi 8V A3/S3 Wheel & Tire Fitment Guide
    Order Now:
    Audi A3/S3 VS-5RS
    Our forged Sprint™ line was built to be extremely light while still offering a meaningful strength increase over our flow formed wheels. Engineered for drivers looking to shed as much weight as possible to improve lap times.
    ➡︎ 10K ton forged 6061-T6 aluminum
    ➡︎ Stronger Sprint™ spec inner lip
    ➡︎ Side-milled spokes for reduced weight
    ➡︎ Massive brake clearance
    ➡︎ Unmatched replacement program
    ➡︎ Lifetime structural warranty
    ➡︎ Independently tested and certified
    10K Tons Of Pressure
    Our new forgings weigh as much as 120 pounds before machining. To form such a thick blank we require special equipment capable of 10,000 metric tons of pressure. This extreme pressure increases the strength of the aluminum by eliminating porosity and improving the grain structure.
    True Motorsport Blanks
    Many companies use 3rd-party blanks intended for non-motorsport wheels which can severely limit sizes, concavity, spoke design, and critical brake clearance. We designed our very own blank profiles from scratch which gives us total control over the final product, resulting in exceptionally deep spokes and stronger designs.
    Learn more about our true motorsport blanks.
    Side-milled Spokes
    One of the most significant upgrades to our Sprint wheels is the addition of wider and deeper side-milled spokes. Any excess material that doesn’t add strength is carved out using a precision CNC ball cutter. Side-milling is often deemed cost-prohibitive by others, but for true performance without compromise we believe it's essential.
    ➡︎ 40-50% Wider
    ➡︎ 50-100% Deeper
    Learn more about our wider and deeper side-milling.
    A Stronger Lightweight Wheel
    Our forged Sprint™ wheels are lightweight without the strength compromises found on typical lightweight wheels. First, we carved out as much material as possible, then we purposefully added one pound back to reinforce critical areas, creating a stronger inner lip and a higher load rating.¹ What’s the point of a lightweight wheel if it’s fragile?
    Weight Optimized
    We conducted extensive Finite Element Analysis (FEA) to reinforce high-stress areas and to remove material where it didn’t improve strength. The result is a wheel that is exceptionally light without the strength compromises found on typical lightweight wheels.
    Independently Tested
    We don't rely solely on computer simulations or unverifiable in-house testing. We believe independent testing is critical to protect consumers in this unregulated industry. We chose STL, an independent lab in Ohio, to test our Sprint™ wheels far above JWL standards, including increases in testing duration, impact drop height, and total load.
    Learn more about our rigorous independent testing.
    Tough Inner Lip
    Introducing the Sprint™ spec inner lip, with a unique channel profile that makes it even stronger than our previous designs. So even though our Sprint™ wheels are pounds lighter than comparable flow formed wheels, the inner lip is 32% stronger.
    Learn more about our Sprint™ spec inner lip.
    Big Brake Clearance
    From day one, APEX has been on a mission to build wheels that clear big brakes. Our new forged wheels are the product of everything we’ve developed over the past 10+ years, including an innovative high-clearance barrel design and vehicle-specific spoke profiles.
    Deeper Concavity
    Our new forgings were redesigned to create extra deep, concave spoke profiles. Their new shape allows us to make any profile, from flat to deep and everything in between. Each one is optimized for a specific application using 3D laser scans of factory and aftermarket brake kits.
    Paintless Knurled Beads
    Whether it's a day at the track or months of street driving, repeated hard braking and acceleration can make a tire slip along the bead seat and go out of balance, causing vibration. Knurled beads help, but are less effective when painted over. Our forged line features unpainted knurled beads that stay sharp and maximize grip.
    Learn more about why our forged wheels have unpainted knurled beads.
    Built for impact sockets
    Track wheels need track tools. Don’t settle for wheels that require undersized tuner lugs or thin walled sockets. All APEX wheels accommodate over-sized race lugs and impact sockets to make swapping wheels lightning fast.
    Laser-Engraved Specs
    As track enthusiasts ourselves, we know how frustrating it is to try to locate and decipher wheel specs that have been hastily hammered into the rim or become unreadable over time. With our new Sprint™ wheels, we chose to invest a little extra and laser-engrave the specs on the barrel, in plain sight, making them easy to find and read. (You’re welcome.)
    Additional Features
    Hub Centric - All APEX VW/Audi wheels with a 5x112mm bolt pattern are purpose-built featuring a 57.1mm center bore. No centering rings required.
    Center Caps - We don't charge extra for caps and we design our wheels to be interchangeable with the OE center caps for enthusiasts seeking a clean factory look. All wheels come with our gloss Black APEX caps included. We also offer optional gloss red and gloss blue VW/Audi spec APEX caps.
    Hardware - APEX wheels can be used with all OEM VW/Audi R13 Ball Seat mounting hardware, OE-Spec aftermarket hardware, and wheel spacers.
    Lifetime Warranty
    All APEX wheels come with a lifetime structural warranty against defects in workmanship and materials, plus a 1-year finish warranty. Exchanges are fast, easy, and hassle-free.
    Learn more
    APEX Wheel Replacement Program
    Curb rash or pothole damage on the street? Make an oopsie at the track? We’ve all been there. APEX is proud to offer 50% off replacement wheels, no matter the damage.
    Learn more
    A Fitment For You
    We’ve tirelessly test-fitted hundreds of setup combinations in order to provide direct-fit, spacer-free wheel packages for everything from showroom-fresh cars to all-out race builds. Our detailed fitment guides help you avoid costly trial-and-error and walk you through every step of finding your perfect setup.
    Explore our Audi 8V A3/S3 Fitment Guides
    Explore our Audi 8V RS3 Fitment Guides
    Explore our Audi 8J TT RS Fitment Guides
    Explore our Audi FV/8S TT RS Fitment Guides
    Questions?
    Call: 925-245-0773
    Email: [email protected]
    Web: www.apexraceparts.com
    Hours: M-F 9a-5p PST
    Nov 03 2021
    Bay Area
    Reserved
    Nov 03 2021
    Bay Area
    Reserved
    Veteran Member Three Rings XMetal's Avatar
    Nov 02 2017
    CA
    Any plans for offering the VS-5RS in 18" setup?
    2018 Audi S3 Premium Plus
    Navarra Blue Metallic/Magma Red - Technology, Dynamic, S Sport, Black Optic, Resonator Delete, Unitronic Turbo Inlet, EQT Stage1 ECU/TCU
    Nov 03 2021
    Bay Area
    Quote Originally Posted by XMetal View Post
    Hi there,
    Originally we planned to offer our forged VS-5RS in an 18x9" ET42 but we ran into some brake clearance issues with that particular design. That said, we are still planning to offer 18" VW/Audi MQB specific forged wheels but we have pivoted to an all-new yet to be released design to ensure we are able to clear all of the popular brake setups in that market. Stay tuned for more details on that new wheel to be announced in the coming months!
    In the meantime, we also offer our flow formed SM-10 wheels in 18x8.5" ET43 and 18x9" ET42 MQB fitments that offer a perfect setup for the A3/S3/RS3 chassis.
    -Geirsen
    Nov 03 2021
    Bay Area
    When we initially sought to develop the lightest and best-performing 17" track wheel possible for the Audi S3, we knew brake clearance would be the trickiest thing to get right. With exhaustive fitment testing and brake scanning using our Creaform laser, we were able to get our 17x9" ET42 VS-5RS dialed in perfectly for the 8V S3 chassis. With a flush and aggressive track-focused fitment that can support popular 255/40-17 200TW and R-compound tires, the 17x9" ET42 VS-5RS offers everything you could possibly need in pursuit of faster lap times.
    This particular 8V S3 was tested using a Brushed Clear 17x9" ET42 VS-5RS wrapped in 255/40-17 Hankook RS4 200TW tires at all four corners. Enjoy!
    Nov 03 2021
    Bay Area
    A new Sprint™ Line design is coming soon.
    Exciting news - the next member of our Forged Sprint line family is on the way!
    Sign up at the link below to be the first to know about fitments, finishes, and Group Buy discounts.
    Upcoming APEX Forged Sprint Line Design
    Nov 03 2021
    Bay Area
    We're one week away to reveal, are you ready?
    Dec 07 2021
    Columbia, MD
    Will they be 18's?
    Nov 03 2021
    Bay Area
    That is correct! These new forged wheels that we plan to officially unveil soon will be offered in an all-new 18" fitment specifically developed for the RS3 and TT RS. Stay tuned for more details to be announced in the near-future!
    -Geirsen
    Nov 03 2021
    Bay Area
    Introducing the Forged SM-10RS. An ultralight version of our already popular SM-10 design.
    We’re a function-over-form brand, so we took our time and engineered this wheel to be our best. The original SM-10 has been re-engineered with thinner spokes and extra-deep side-milling for maximum weight reduction. The SM-10RS is now our lightest wheel in some fitments and meaningfully stiffer than our popular VS-5RS.
    Just like all Forged Sprint™ Line wheels, the new SM-10RS features:
    Sprint Spec Inner Lip
    Fully Forged from 6061 Aluminum
    Massive Spoke and Barrel Clearance
    Un-Painted Knurled Beads
    Lifetime Structural Warranty
    Unmatched Replacement Program
    Click here for more details and to see a list of fitments for your specific chassis.
    APEX SM-10RS
    Click here to join one of our active Group Buys to get deep volume discounts on our existing VS-5RS and EC-7RS forged wheel designs, or to be among the first to pre-order the all-new SM-10RS!
    Sprint Line™ Group Buy
    Curious about fitment? We've got you covered!
    Nov 03 2021
    Bay Area
    Our biggest sale of the year is now live! Don’t miss your chance to lock in a deep discount on sets of our Forged and Flow Formed wheels as the holiday season kicks off. All our wheels are on sale with huge discounts available sitewide. Free shipping will also be available for all orders during the sale.*
    Buy Now
    15% off Sprint Line Forged Wheels
    Our popular Forged offerings at an even more affordable price. Save 15% on the lightest wheels we make including our VS-5RS and SM-10RS designs.
    20% Off Flow Formed Wheels
    A better value than ever, our Flow Formed VW/Audi SM-10 wheels are 20% off across the board. With 17" and 18" options in both OEM+ and aggressive track/street fitments available, there's a perfect fitment out there for every car.
    Spacers and More
    Caps, Spacers, Studkits, Bolts, Nuts. No matter what you need to get your fitment dialed in, our sale has you covered with a 20% discount on these critical upgrades for your VW/Audi.
    With a variety of options on offer be sure to consult our Fitment Guides before ordering. If you still have questions, our fitment experts are standing by to help with inquiries, but will be overwhelmed as we near the sale’s end. Beat the procrastinators and reach out early for help with your next set of Apex wheels.
    Buy Now
    Need time before you buy? This sale ends on November 30th at midnight PST.
    *Free shipping to the lower 48 US states
    Questions?
    Call: 925-245-0773
    Web: https://apexwheels.com
    Nov 03 2021
    Bay Area
    Our largest sale of the year is already halfway over, don’t miss out on these savings. We have all of our Audi wheels on sale at 15-20% off along with Apex accessories like spacers, stud kits, and center caps.
    If you have any questions regarding fitment or other technical wheel/tire details, feel free to check out our Audi fitment guides via the following link:
    APEX Audi Wheel & Tire Fitment Guides
    If you can't find the answers you're looking for in the guides, you can send us a message using our fitment form.
    Buy Now
    Questions?
    Call: (925) 245-0773
    Web: apexwheels.com
    Nov 03 2021
    Bay Area
    Our biggest sale of the year is extended for 24 hours! This is your last chance to lock in a deep discount on sets of our Forged and Flow Formed wheels. On top of huge savings, free shipping will be available for all orders during the sale.*
    With a variety of options on offer be sure to consult our Fitment Guides before ordering. If you procrastinated a bit, that’s okay! Our fitment experts are standing by to help with any questions you may have.
    You can find our Audi-specific fitment guides via the following link:
    Buy Now
    Questions?
    Web: apexwheels.com
    Nov 03 2021
    Bay Area
    Put that refund to work with our Tax Season Sale ongoing now. Save up to 25% off + Free Shipping* on a huge variety of in-stock fitments. Every Sprint Line Forged and Flow Formed wheel we offer is on sale. This sale ends on April 22nd, but discounts apply while supplies last. Get your order in today!
    Apex Flow Formed: Up to 25% off
    Apex Sprint Line Forged: Up to 15% off
    The Lightest Wheels We Make. Deep discounts on all of our Fully Forged SM-10RS and VS-5RS are available making our high-performance lightweight wheels an even better value.
    Apex Accessories: 15% off
    All Apex Studkits, Lug Bolts, and Centercaps are discounted and get free shipping. Get your car ready for the track season today.
    Free Shipping
    All orders of wheels and qualifying Apex accessories will get free shipping* through the 22nd.
    Fitment Guides
    We know what fits. From direct bolt-on to all-out race fitments and everything in between. We've street and track tested extensively to save you the trial-and-error.
    *Free Shipping to the 48 Contiguous States only.
    Questions?
    Call: 925-245-0773
    Web: www.apexwheels.com
    Nov 03 2021
    Bay Area
    Some of you may have already seen the reveal of this project on our instagram, but we wanted to reach out to the Audi community on the forums as well to collect feedback about the development of a new wheel design.
    Project ML-10 Background:
    After Josh, one of our Senior Product Engineers installed a widebody kit on his race car project, he had to design a custom set of wheels to fit his extreme application. Originally a one off project, when he showed the team what he created, we were floored. And our community was too when we shared a picture on Instagram and Facebook.
    We’ve made it an official project, but to make this wheel a reality, we need you to decide on some of the details by taking our survey.
    Need more information? Subscribe to our newsletter and check out project updates along with additional photos on our website.
    Jun 13 2024
    Hey there, new 8Y owner here looking to downsize on wheels. Looking forward to the VS-5RS to come back in stock in 17x9!
    Nov 03 2021
    Bay Area
    Quote Originally Posted by napkintosh View Post
    The 17x9" ET42 VW/Audi spec VS-5RS will be back in stock soon within the next month or two. You can find them on our website via the following link: https://apexwheels.com/wheels/forged...Size=17x9-et42
    -Geirsen
    Nov 03 2021
    Bay Area
    ML-10RT now available for Pre-Order
    The ML-10RT forged wheel started life as an engineering passion project. You brought it to life.
    It’s the moment you’ve all been waiting for. The green flag has dropped and the Forged ML-10RT pre-sale is officially underway! Reserve your set now to ensure you receive wheels from the first production batch, and save 15% off + free shipping in the continental U.S. Due to extremely high demand, we expect a number of popular fitments and finishes to sell out, so act fast. Pre-order discounts are based on product availability, and are subject to change at any time. Please note we fulfill orders in chronological order, so the sooner you place your pre-order, the faster you will get your wheels.
    Features
    AN EVOLUTION OF PERFORMANCE - The ML-10RT honors the motorsport designs so many of us fell in love with during the golden era of Touring Car and Sports Car racing. However, its ancestry ends there. Our in-house engineering team pulled out all the stops to create a monoblock forged wheel that's lighter, stronger and stiffer than multi-piece wheels of the past. Utilizing the latest forging technology to offer an impeccable design, backed by Real Performance, at an obtainable price point.
    SIDE-MILLED SPOKES - The ML-10RT incorporates Apex’s extra-deep, side-milled spokes. Any excess material that doesn’t add strength is carved out using a precision CNC ball cutter. Often deemed cost-prohibitive by others, this aggressive side-milling shaves critical weight, and adds a sharp contrast in the design of the center spoke area.
    SPRINT INNER LIP - The ML-10RT borrows the race-proven Sprint Spec inner lip from our Sprint Line wheels, providing critical strength to the unsupported inner lip of the wheel. Adding 32% more material where it matters most. Don’t settle for under-engineered wheels, attack both the track and your cities potholes with confidence
    10K TONS OF PRESSURE - To make our forged wheels the strongest we can, we applied as much pressure as possible using a 10,000 ton forge. This extreme pressure increases the strength of the aluminum by eliminating porosity and improving the grain structure.
    TRUE MOTORSPORT BLANKS - Many companies use 3rd-party blanks intended for non-motorsport wheels which can severely limit sizes, concavity, spoke design, and critical brake clearance. We designed our very own blank profiles from scratch to give us total control over the final product.
    INDEPENDENTLY TESTED - We don't rely solely on computer simulations or unverifiable in-house testing. We believe independent testing is critical to protect consumers in this unregulated industry. Our Touring Line wheels are independently tested by ITS at their Michigan facility following JWL standards but pushed to much higher loads and much longer durations.
    MACHINED LIP - The ML-10RT is our first forged wheel to feature a machined lip, which really makes it a standout design within the Apex catalog. The lip in combination with the mesh center pays homage to the glory days of motorsport, and is sure to dramatically transform the look of any car. The best part - the machined lip has a gloss clear coat and doesn't require polishing.
    VEHICLE SPECIFIC SPOKE PROFILES - The lipped design of the ML-10RT inherently limits brake clearance. Rather than making every fitment as conservative as possible, we utilized our extensive 3D vehicle scanning library to shrink wrap each fitment's spoke design around respective OEM and popular aftermarket brake kits. Leveraging our vehicle research and engineering team, we find a perfect balance of concavity and brake clearance.
    BUILT FOR IMPACT SOCKETS - Don’t settle for wheels that require undersized tuner lugs or thin walled sockets. All Apex wheels accommodate over-sized race lugs and impact sockets to make swapping wheels lightning fast.
    OEM CENTER CAP COMPATIBILITY - Love that OEM+ look? Us too. Our engineers went the extra mile and incorporated a flush mounted OEM center cap support into the ML-10RT. Whether you want to show off your included Apex center caps or stick with your OEM caps, the ML-10RT will seamlessly accept both.
    LASER-ENGRAVED SPECS - As car enthusiasts ourselves, we know how frustrating it is to locate and decipher wheel specs that have been hastily marked on a wheel or become unreadable over time. Our Touring Line wheels have laser-engraved specs on the barrel, in plain sight, making them easy to find and read.
    Pre-Order your set of ML-10RT today
    Buy with confidence. With only a 25% deposit initially required for these wheels, you can Pre-Order today and lock in the deep discount and ensure you get your preferred fitment and finish early. Don’t miss your chance to be the among the first to run this all-new Apex design.
    Check out your vehicles wheel configurator or Fitment Guide for available wheel sizes and fitment information such as tire options and brake clearance.
