Results 1 to 9 of 9
Thread: Springs
    Feb 23 2022
    Montenegro
    Springs
    Currently I have on my fwd a4 1.8t koni shocks and eibach black springs.Car is driven daily sometimes goes to country side a bit loaded.I want to go lower to have more stability in corners but idk what should I take for my needs...
    Послато са SM-G960F помоћу Тапатока
    Veteran Member Three Rings QuattroBucc's Avatar
    Mar 06 2020
    B5A4 1.8TQ g25-660, MK4 GLI K04
    Santa cruz, CA
    Rear sway bar upgrade is a huge improvement in cornering
    Feb 23 2022
    Montenegro
    Reccomendation?
    Jun 30 2008
    Erie, Pennsylvania
    B5 likes a lot of rear sway bar. So any of the 25mm rear bars are a good match for sport springs. Popular items are 034 motorsport, Hotchkis, H&R, etc.
    Example, 034 Motorsport Rear bar:
    https://www.034motorsport.com/034mot...djustable.html
    However, the rear subframe area where the sway bar bolts onto the car is relatively weak and not well supported on the B5. So it is highly recommended to add a bolt-in support bracket (or weld in such a support out of steel yourself). Without this you can crack the sway bar mounting area right off the subframe.
    Reinforcement Bracket:
    https://www.034motorsport.com/billet...4-quattro.html
    Feb 23 2022
    Montenegro
    I saw this,do you have any links for europe only?
    Jun 30 2008
    Erie, Pennsylvania
    I'm not familiar with any retailers in Europe. Hopefully somebody across the pond can chime in with some suggestions.
    Veteran Member Four Rings Blazius's Avatar
    Mar 15 2018
    Europe
    Guys, hes FWD. AFAIK the only rear sway bar upgrade over the beam stock was the sway bar made by Neuspeed but its NLA anymore.
    Honestly there is not much you can do, buff up the rear springs with rubber/poly inserts, polybush the whole car and thats it. Quattro is much better.
    Jun 30 2008
    Erie, Pennsylvania
    Ooh nice catch. Totally missed that it was FWD.
    Feb 23 2022
    Montenegro
    Quote Originally Posted by Blazius View Post
    I would polybush the car but idk the dimension of bushes,whole set is like 250 euros which is not too much if car would be stiffer
