Results 1 to 10 of 10
    Established Member Two Rings 613b8s4's Avatar
    Jun 30 2022
    2011 6MT S4, 2021 Explorer ST
    Ottawa Ontario
    Supercharger bleeder screws stripped
    I was replacing bleeder screws and stripped the head off of one. I tried to cut a line into it to turn the remainder out with a flat head but the heat has deteriorated the plastic to the point where my flat head would just break it apart and now there’s just pieces of it stuck see photo. If I get most of it out of the threading how bad is it if there is tiny pieces of plastic left over in the system something that may have fallen in that I can’t see?
    Any body have any experience with this any tips would be greatly appreciated thank you image-2022-12-30-17:26:43-900.jpg
    2011 6MT PHANTOM BLACK PEARL, 034 STAGE 2+ WMI 034 INTAKE 034 MOTORSPORT ENGINE MOUNTS 034 DRIVETRAIN MOUNTS BILSTEIN B8 SHOCKS 034 STRUT MOUNTS H&R SPORT SPRINGS CTS HX CTS CATBACK EXHAUST CAP TEST PIPES CAP V2 CARBON DIFFUSER CAP HIGH KICK CARBON SPOILER iABED THROTTLE BODY JXB SS INSTA: @613_B8S4
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Senior Member Three Rings JRYtheS4's Avatar
    Sep 08 2020
    It's fairly easy to remove the supercharger if all else fails. If it were me I'd pull the supercharger and chip the old screw out with it upside down.
    Sent from my SM-G991U1 using Audizine Forum mobile app
    2011 Audi S4 Prestige 6MT|Full ADS w/ sport diff|Meteor Grey Pearl|Black/silver alcantara|Aluminum trim
    Bone stock except intake
    Jun 30 2022
    Ottawa Ontario
    yea I fucked it up now need new intercoolers. problem is the oe ones are all backordered can only get the ones from Audi at like $600 each. are they the same part for both sides? I may have found some online for $359
    Sep 08 2020
    Quote Originally Posted by 613b8s4 View Post
    Whoops. Yeah same part, both sides.
    Get them from FCP in case they fail in the future.
    Jun 30 2022
    Ottawa Ontario
    ok next question, what else do I need when changing the intercoolers? I just had a supercharger off service less than 1000 kms ago. carbon clean pcv pump thermostat etc. do I need all new gaskets again?
    Sep 08 2020
    https://www.fcpeuro.com/products/aud...w-06e145621skt
    This kit shows the part numbers for all the gaskets. The intercoolers come with the rectangular gasket. I would definitely get coolant pipe o rings. There's an o ring that goes around the round end of the intercooler tank that I would replace too but I'm unsure which is it in this list. Should be 2 of them.
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    https://www.ecstuning.com/b-mahle_be...6e145621s~mbr/
    get mahle version( still oem some.even have audi symbols on them . mine did) . u can get 2 for price of 1 genuine audi part.
    EDIT: THEY ARE NOW BACk ORDERD they werent last week.
    Sep 08 2020
    Quote Originally Posted by f4m0u5 View Post
    If you get them at ECS they will say they're stocked but in actuality they may be backordered until June lol. They aren't great about that.
