Results 1 to 4 of 4
    Apr 19 2019
    San Diego
    Replacing the Water pump engine support help
    Hello i will be replacing the water pump on the 19 TTRS this weekend and wanted to get a little input on supporting the engine. Will it be the normal block of wood on the oil pan and/or transmission case? I'm a little uneasy since the oil pan is quite soft so i wanted to figure out what has worked before i go breaking stuff . I have an engine support bar but not sure if that'll be more in the way or just not a good idea, thanks everyone
    Nov 11 2021
    Atlanta, GA
    Quote Originally Posted by Jainuss View Post
    Dealer used a cherry picker and an attachment to the block to support when they did mine fyi. Not sure the alternatives.
    Senior Member Two Rings TwistRate's Avatar
    Jul 22 2018
    Twin Cities
    Yea I think I would try to provide lift from the top .... as that would also allow for some movement rather than a static block of wood. I would NOT use the oil pan to support any load!
    Apr 19 2019
    San Diego
    Ill give that a shot, thanks for the advice
