Results 1 to 18 of 18
    Oct 27 2015
    Phila
    For those that own a b8.5
    For those that own a b8.5 (A4, A5, Q5)
    How much oil do you burn per 1,000 miles?
    Do you currently just live with it?
    Do you plan on rebuilding it (piston ring job)
    Asking because my stage 2 2009 A4 burns no oil (was repaired via Audi during lawsuit) but I recently got a 2015 Q5 that seems to burn what looks to be a quart or so every 3k miles (I imagine it gets worse?)
    I love the Q5 and I plan on keeping it for awhile since it has low miles for a used older SUV (under 60k) and it drives like a dream.
    Nov 30 2016
    B8.5 allroad stock for now. B6A4 avant
    northfield, ma usa
    2013 allroad CPMB engine code. 500ml every 5000 miles. Bought used at 109k miles currently 184000 miles.
    Established Member Two Rings A4fuzz's Avatar
    Jan 13 2017
    2019 Audi RS5 Sportback / '21 Acura TLX SH-AWD Advance
    Ohio
    I've been APR K04 for about 40k miles, driven hard daily and I don't use any oil between oil changes (5k miles) Currently at 77k miles
    2015 A4 Premium Plus ~ Sport Plus ~ Black Optics ~ APR K04 ~ APR Stage II 93/E85 ~ APR Downpipe ~ APR FMIC ~ APR Carbonio intake ~ R8 Coils ~ 034 Billet Drivetrain Mount Inserts ~ 034 RSB and Links ~ 034 X-Brace ~ Canyon Run CR-15 Strut Brace ~ S4 Front and Rear Brake Upgrade ~ Drilled & Slotted Powerstop Rotors ~ ECS Stainless Steel Lines
    Dec 29 2017
    Phoenix, AZ
    2015 AR with CTS BW K04 at 90k miles...lots of upgrades, no actual internal work done. Usually run E85. Burns zeo oil.
    2010 Avant burned massive oil so I swapped it for a B8.5 Q5 motor. Now runs a CTS BW K04 and other upgrades. Again nothing internally done. Burns zero oil.
    2010 Avant // 2015 Allroad
    Feb 15 2016
    Cambridge,Ontario
    my 8.5 burned a quart every 180 miles. I rebuilt it
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Veteran Member Four Rings MyDimeIsUp's Avatar
    Dec 04 2019
    West Chester, PA
    2013 B8.5 allroad with CPMA engine. Used to burn 1qt/1,700 miles when I bought it with 133k. I'm at 156k and feel like the burning is getting worse. I did a rough estimate and I think I'm around 1qt/1,000 - 1qt/1,200 miles
    2020 BMW M340i xDrive - Mineral Grey
    2012 Audi A6 3.0T Prestige - 034 Stage 1 ECU and TCU | CTS Turbo Intake | 034 Street Density Motor Mounts w/ JHM Trans Insert | ECS X-Pipe
    2013 Audi allroad - RIP
    2007 Toyota corolla
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    2013 A5 CAEB with 80k miles
    Burns ~ 6oz/5k miles
    Fingers crossed
    Oct 27 2015
    Phila
    2015 Q5, burns about 1/4th quart every 280 miles. At this rate, I’m still in Audis oil burning spec.
    I think I saw something about an extended class action lawsuits for all b8 to hopefully include b8.5’s…
    Veteran Member Four Rings Perry01's Avatar
    Jan 22 2016
    Touareg V8 FSI 8V A3 - B8.5 Q5 - MKVI GTI
    Hawaii and Utah
    2013 Q5 with a CPMA that burns zero oil.
    CPMA / CTS K04-0064 / IE custom tune / Wagner FMIC / Custom ZF8 TCU tune
    Junior Member One Ring
    Jul 15 2021
    1986 Mazda Rx7 - Turbo II swaped
    Quebec
    2014 AR CPMB engine. Burns 1 quart every 2200km (1360mi). Oil change every 5000km (3100mi). Bought the car at 172k km (106k mi), nearing 200k km (120k mi).
    Living with it right now, no plan on rebuilding yet but that might change. Plan is to test out piston soak with Berryman B-12 Chemtool and go from there.
    JM
    -2014 A4 Allroad
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Markham, Ontario. Canada
    2015 A4 - 224,000 kms. Was burning through about 1ltr per 1000kms, but recently improved, for no apparent reason, to 1ltr per 1500 kms.
    I'm living with the top ups every three weeks. Doing oil changes every 5,000 kms since 140,000 km
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
    Senior Member Three Rings hkdolphins's Avatar
    Dec 03 2014
    Noggy Avant, B8.5 Allroad
    SF/CA
    Quote Originally Posted by 4xaudi View Post
    I also has 13 allroad, started to burn oil at 120K, 1/4qt for 5K now. How many miles when your one started to burn oil? thanks
    B6 Noggy Avant, B8.5 Allroad
    Jun 21 2019
    Boston
    CPMB, 56k, Stage 1 for 10k, no oil so far. I'm hoping the Audi Oil Gods will be kind to me after the B6 S4
    2015 B8.5 A4 P+ ZF8 | Sport Pkg | APR | Alu-Kreuz | CR-15 | 034 RSB | CTS DP
    2004 B6 S4 6MT (Sold)
    Senior Member Three Rings Seal1968's Avatar
    Apr 04 2015
    Ontario
    2013 A4 2.0...296,000 Kms, burns no oil as yet. OCIs every 5,000 Kms.
    May 10 2015
    Pittsburgh PA
    2013 A4 CAEB no oil loss during my 5k oil change interval, currently at 117k miles
    Veteran Member Four Rings RockJGC's Avatar
    Sep 28 2014
    NY/NJ metro area
    I change my oil every 5,000 miles on my 2016 and it still shows as full on the dipstick right before every oil change.
    Jul 07 2021
    New York City / Connecticut
    Quote Originally Posted by Danzzo View Post
    I have a B8.5 with the CPMB motor. It burned a quart per every 200 miles for about 30,000 miles. I ran some LiquiMoly Jectron through a tank of gas. It improved to a quart every 400 miles. I'm gonna run Liqui Moly Engine Flush with my next oil change. My buddy has a CPMA that burned a quart every 600 miles, after the Jectron and then the engine flush, his improved to a quart every 1500. The oil burning in these cars is caused by piston rings getting clogged with sludge as a result of relief holes that are too small to let the oil seep down into the crankcase when they get just a little dirty. There's nothing inherently wrong with the way the engine itself is built or put together. I don't intend to rebuild this engine, but I do intend to drive it till it dies (which hopefully won't be for another few years). If I were you I'd try out this stuff; My car has over 205,000 miles on it and still runs great. I don't see why yours won't if you just keep adding oil and take care of it. There are some people who will disagree with me and they are rightfully concerned, but I don't have the time or money to completely rebuild the engine on a high mileage car I use just for transportation, especially if it functions perfectly fine while burning some oil.
    Established Member Two Rings sjarvis's Avatar
    Jun 22 2007
    2015 allroad, utopia blue, p+, sport, 034 F/R sway, APR stage 1
    Colorado Springs, CO USA
    2015 allroad- zero oil burning- 70K miles. Oil changes every 5K miles. APR stage 1 (highly recommended!)
